someone anyone. help . avcr pinout.
Discussion in 'Modifications & DIY how-to' started by YOMANDO, Apr 15, 2008.
  1. YOMANDO
    YOMANDO Member
    does anybody have the pinout diagram for an 04/05? i would like to install my avc-r.:sx:
  2. pEd
  3. Alex
    Nice pdf :)
  4. YOMANDO
    YOMANDO Member
    is that the pinout apexi uses to install the avcr. Ive seen some apexi uses that shows
    where to splice into the ecu.
  5. pEd
    You just have to cross-reference it.
    When the AVCR is looking for the vehicle speed wire, look it up on the pdf from that link.
    Make sure you're soldering it in. I did not have any luck when I tested it using vampire clips.
    If you're not comfortable with that, then I would HIGHLY suggest getting BatlGround or TopSpeed
    to install it for you. You don't want to be mucking up your ECU wiring.
    Also, IIRC one of the wires is a different color for the 05's (and in another pin location), so you may need to search on that one.
  6. YOMANDO
    YOMANDO Member
    looking for experience on helping me install this avcr without having to make trip to
    topspeed or balance performance.
  7. YOMANDO
    YOMANDO Member
    thanks balanced performance
    :bowdown:they did a great job and from the conversation they are trying to get a awd dyno within a year.
