Does anyone know what would be the best springs for an everyday driver with oem shocks this is for an 06 wrx
I got STi pinks. They have the same rates as stock STi springs, a noticeable increase over stock and still supposed to be good for use with stock struts. Also, you could find some used for fairly cheap (from an 04 STi)
There is a group buy over on NASIOC for Crucial Racing springs. Very similar to the STi pinks, but priced a lot better.
Nasioc has a good faq on lowering springs and suspension in general you might want to check out. Here's the link for the lowering springs http://forums.nasioc.com/forums/showthread.php?t=1383366
So in your opinion what is better overall; adjustable coil overs, or just a good shock and lowering spring?
Daily driving its always better to have a strut spring combo. Most coilovers do not have great dampening on full soft. You will most likely bounce a lot. You do sacrifice spring rate with a spring and strut, but unless you are doing some serious racing you won't realize it. I recommend the espiler's and the RCE's.
My car wont see the track much maybe 2 times a year, but I do love my trips to the mountains, As far as comfort would I see any difference between the 2? Thanks for the input.
