Squeeky sound from the rear.
Discussion in 'Modifications & DIY how-to' started by cannarella, Dec 16, 2008.
  1. cannarella
    cannarella Member
    I got a hitch installed on the wagon a month or so ago and ever since I have heard some metal squeaking when going over bumps and general shaking when driving the car. I am thinking that it is where the STI tip is hitting the hitch. Just need a second opinion to be sure and then what is going to be my resolution. I am thinking if the outer shroud has a gap before the actual exhaust pipe I can mark the area, drop the axle back and cut out the outer part on the tip to clear the hitch. The tack weld looks like it is out of the way so I should be able to do some cutting without any problem. The squeaking is really starting to annoy me.
  2. Do a hammer modification with a big screwdriver..just angle it in aginst the area that is hitting and whack it..
  3. lostinthewoods
  4. cannarella
    cannarella Member
    Yeh already tried to pull the exhaust down and the hangers are holding tight. I may just go get a new axle back gasket and pull it on Saturday when I am changing fluids and do a cut out. The screwdriver and BFH is tempting though.
  5. undrgrndrdr15
    undrgrndrdr15 Active Member
    not sure if your hangers have hole in the center but if they do seperate the hole and put something between it... it will give a little extra room... if that makes since...
  6. cannarella
    cannarella Member
    So wedge something in there to make them longer?
  7. undrgrndrdr15
    yeah we did that at the shop i worked at... sometimes metal would settle or rise a bit as the welds cooled... we would just stick i nut or anything that fits in the middle of the hanger and it normally gives enough room... just pry the exhaust down so it opens and then place something in there, adjust the size for the amount of movement you need
  8. BrianGT
    I ran the Kartboy long hangers, which lower it a little bit and let it clear the hitch.
    Size difference:
    -Brian
  9. wrxin8or
    squeaking/rattling in a subaru?
    get used to it;)
  10. cannarella
    cannarella Member
    Rattleing I can handle, the squeaking it a bit annoying. :)
  11. undrgrndrdr15
    let us know what you end up doing and if it works...
  12. pEd
    I agree with Keith and Brian. Get the longer exhaust hangers.
  13. amonsta
    amonsta Member
    I think I mite have a couple in the garage if u need??
  14. crash#2
    crash#2 Member
    long urethane hangers help alot but a hitch is so easy to take off and re-install that that's how i do it now. tried everything. folding a peice of cardboard up and shoving it between the two is a good temporary fix.
  15. cannarella
    cannarella Member
    Sorry for the delay. It was actually between the exhaust hanger on the left and the side of the hitch mount. I don't think the pic was the exact source. I put a piece of foam rubber in between them and it stopped. Now it is time for a new battery...
