Stage 2 for under $400
Discussion in 'Modifications & DIY how-to' started by moose, Sep 23, 2006.
  1. moose
    Helix downpipe (catless): $199
    Gutted uppipe: $0
    STi catback: ~$75
    OpenPort cable: ~$90
    Gaskets+shipping: $cheap
    Much faster car for under $400? Priceless.
  2. goixiz
    goixiz Active Member
    even cheaper
    Shorty DP = ~$125
  3. moose
    Then maybe stage 2 for < $350. :)
    Throw in modded stock injectors ($free), ebay intercooler (< $200) and a good deal on a VF39 ($250?), LC-1 wideband ($200), and you have the potential for, what, 280-290whp for under a grand.
    (Might want to spend another $100 or so on a fuel pump to play it safe now that I think about it...)
  4. crashtke
    modded would be too much for the 39 wouldn't they? I hear they flow like 750...now pinks or the new 06 injectors would be perfect!
  5. jayj713
    jayj713 Member
    do you have to get a tune? or do you just do that with openport or whatever?
  6. crashtke
    ya, he is talking about modding the ECU with open port. It has the ability to reflash the ECU.
  7. moose
    As long as the car can idle fine the injectors aren't too big. Granted you'd probably only see like 60% IDC max, but who cares?
    Pinks would be good too, but costlier... I think the '06 injectors are side feed so they wouldn't function well.
  8. nsvwrx
    nsvwrx Active Member
    are they side feed? i was under the impression they were tops.
    other than that, for stage 3 i spent a total of 960 bucks.
  9. moose
    Could you break that down?
  10. miloman
    SS had posted saying that 06 WRX injectors are top feed
  11. crashtke
    Ok just to clarify...STI are side feed or top feed?
  12. miloman
    USDM STi injectors are side feed
  13. crashtke
    Ok so I was correct in my assumption that the new WRX injectors for the 06 that flow 560 can be used on WRX. These would be a good lower cost alternative to the JDM pinks...hell they might even be hitting the market soon as people put bigger turbos on the 06 wrx and go to 800's, etc.
  14. nsvwrx
    250 for catback, 150 for catted dp, 80 for up 600 for AP 300 protune 100 ic houses - 1480 - 600( subaru bucks) = 780 =)
    but for 1480 stg 3 isnt that bad. car feels damn great.
  15. moose
    Looks like you're right. What do they go for new?
  16. moose
    Ah, I was wondering what you meant by 'stage 3'. Damn tuners can't stick to a common nomenclature. :)
    I guess my 'stage 3' would probably be 'stage 4' in those terms, with bigger IC, injectors and aftermarket turbo. Now we just need somebody to try and pull it off for $1k and see if it's doable. :D
    edit: That is if you either have a free Scott (blackmail? unlimited burritos?) or DIY the tune.
  17. siegelracing
    We've got the '06 WRX Top Feed's (they're near 600cc's) for right near $100 each, maybe even just under (have to check with Lisa).
  18. crashtke
    would be a great budget set of injectors! I think last I heard you guys had them for $360 for the set or something...again not 100% on that but what I heard. For my goals I am going to have to go a bit higher with the 18g or super 16. I think the recommendation is a minimum of 700 cc for the super 16 and probably a bit more for the 18g. I found that deadblt has a budget series of td05's for fairly reasonable!!
  19. moose
    FWIW, pinks are $375 shipped from gruppe-s. Hopefully the '06 WRX ones will come down in price. :)
  20. Alex
    So you prefer that 3rd cat in there?
  21. moose
    Everybody should have a cat; no reason to shit on mother nature more than necessary, and a single cat won't rob much hp. :)
  22. goixiz
    Yes i had an option - PERRIN DP (no CAT) still in garage
    I opted for Stromung Coated Shorty DP for the flexibility and while i was patiently waiting i also got a Stromung Catted MP slightly used and it matted perfectly with STi Catback.
    Crucial PPC manifold (w/ stock heatshield)- STi UP - Stock TD04 - Stromung Coated DWG DP - Stromung HiFLow Cat - STi Catback
    Reason: both Audio and environment friendly
  23. crashtke
    Bah these cars still probably put out half that of a big v-8 super SUV gas guzzler. Only reason I have not taken my cat off is not sure how loud it will be and the various classes in autocross, lol.
  24. Alex
    Just curious for your opinion, that's all :p
