Starting FMIC install this weekend
Discussion in 'General Community' started by moose, Jan 6, 2006.
  1. moose
    Feb 5, 2005
    2,969
    0
    Well, still waiting for a couple pieces to arrive (TurboXS flange for using the stock BPV and a TB coupler) but I will probably mount the core and most of the piping this weekend. Should get interesting... not looking forward to cutting the bumper! :eek:hnoes:
    Will try and take plenty of pics.
  2. wrxguy
    wrxguy Member
    Nov 3, 2005
    467
    0
    if you want some help let me know because i have turboxs fmic. If you want to look at mine for refrence. Also i recomend a dremal that has a slow speed on it and have a lot of cutting wheels to cut it.
  3. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    Good luck :bigthumb:
  4. ptc075
    ptc075 Member
    Nov 5, 2004
    112
    0
    Hey if you guys do this this weekend, plz lmk. Now that I have the larger turbo, my next step would be a FMIC, & I'd like to see what's involved. Sadly I'm busy helping a friend move most of this weekend, but lmk when you're going to try this & I'll try & drop by & be helpful. At the least I can bring the Dremel. =P
    -Laters!
    -Chris!
  5. Cool_____
    Sep 5, 2005
    7,338
    0
    You don't need a dremel. Have something nice and flat to lie on the bumper(I didn't do this and my bumper isn't cut straight) and make your outlining line with a pencil or chalk or whatever will mark on the paint. Use a box cutter with a new blade on it. All you have to do is cut past the paint and primer and a little into the urethane and then it will pop right off when you bend it. Take your time and pay attention. I did mine FMIC install in 4 hours. :wiggle:
  6. pEd
    Mar 5, 2004
    2,460
    3
    I remember reading somewhere that you could use a hot-knife as well.
    That way you don't get all the "junk" you'll get from using a Dremel.
    Good Luck.
