Steering Rack?
Discussion in 'Modifications & DIY how-to' started by flat4ever666, Oct 29, 2009.
  1. flat4ever666
    flat4ever666 Member
    So i blew my tranny out about 3 weeks ago. Im currently in the process of pulling it out. While wrenching away i noticed that the boot of my steering rack on the passenger side is ripped. there is some grease and build up but doesnt appear to be leaking. what would be the fix for this a new rack or boot? Im also looking for a 5speed with low miles. thanks guys!
  2. I havent done it with a Subaru, but when I had my 240 I had a tear in the boot and it was all gum'ed up. Clean it off the best you can and grease it back up if necessary. The only time you should need to replace the rack is if you have a knock or click going on. Similar to this.
    http://www.youtube.com/watch?v=qyVWcnHyLKc
    FYI, if you see fluid coming out of the boot, replace the rack. Means you got a piston leaking in the assembly.
  3. Alex
    Let's confirm for argument's sake: Are you sure you do not mean the boots on the axles?
  4. Good point.
  5. flat4ever666
    flat4ever666 Member
    Yep its the steering rack boot.
  6. Matt
    my steering rack boot has a nice hole in it as well. King said it's really nothing to worry about until you start hearing popping just like Clint said
  7. flat4ever666
    flat4ever666 Member
    alright cool, well i guess i need to replace the axle with the ripped boot first to see if the rack is popping.
  8. Alex
    Ah, so there was a torn cv boot in there as well :) Axles click and pop so listen in!
  9. Mike@TTR
    Mike@TTR Active Member
    Boot on my steering rack has been torn for 2 years now I think.
