there was an sti up at SoG about a month ago that had one of these, WJM and i got to take it for a short spin, and man is it hawwwwwwwwwwt
Been thinking about this.. if you have a CarPC setup you could incorporate a datalogger into it. Would be pretty sweet.
tari is the only one out right now for carPC's but digimoto is in the process of making a media version of their software so you can have actual gauges of whatever you want displayed on the LCD, at least the last time i checked up on mp3car.com.
well all but one is taken. i guess i will take $200 over what i paid for it , considering they are imported.
from what i read, you only have to remove the face plate, and remove the green one. btw bidding on the green one will start in an hour, get your wallets ready.
Just curious. I don't really know much about either the Delta Dash, or Psi3. With Delta Dash, do you have to have EcuTek? And with Psi3, do you have to have any other special things to run it?
PSi3 came out with next generation ECU data monitor. It is really bad ass check this out -->> http://bbs.scoobynet.co.uk/showthread.php?t=501990 The most valuable and useful upgrade from previous version, you can use aftermarket EGT sensor (Defi) instead of useless stock egt
