STI lateral links on GC/GM
Discussion in 'Modifications & DIY how-to' started by liltoua, May 19, 2014.
  1. liltoua
    liltoua Member
    I posted this up on rs25.com as well, but here it goes. So people have claimed that running the STI lateral links pushes out the GC/GM geometry out 10mm out each side. Well I currently mounted up the GD rear subframe along with some whiteline adjustable lateral links and saw no difference in the geometry changes.
    Now before you say that I didn't adjust it right. I took the OEM STI lateral links and put them side by side with the whiteline's and adjusted the whitelines so that I could start off at OEM STI length.
    This is where it makes no sense to me. I was running a 20mm spacer in the rear to fill up the gap in my flares. Now with the GD subframe and the whiteline lateral links in place, I figure it would push out my rear by 10mm, so I would only have to run a 10mm spacer. WRONG. I got a 10mm spacer and mounted it to the car and then put on my wheels.....the wheels are sunken in. I then put a 20mm spacer in and it was back to how it was when I was running the stock lateral links.
    I either have the lateral links setup wrong, or the myth has been busted. I mean I could always just adjust the links to extend, but wouldn't that mess up the geometry of the car?
  2. b reel
    GC and GG(02-07 wagon) are the same length
    GD 02-07 WRX and 04 USDM STI are 10+
    GD 05-07 STI are 15+
    Do you have adjustable rear camber plates?
    If those STI links are what you had previously then you were setup with the longest OEM links hence...
  3. liltoua
    liltoua Member
    Yea this rear subframe I bought was from a 05 STI. So technically it should be a big difference. No I don't have adjustable rear camber plates.
    So for the fronts I just bought the bottom piece collar for my coilovers to fit the new 5x114 hubs, but the rears bolt right in. The only thing I can think of is a combo of the tophat mounting point and lateral links of the GD are setup different so that's why I don't see it when I mount it to my car.
  4. b reel
    compare the STI links to the RS links is the next logical step
