STI parts install help
Discussion in 'Meetups & Events' started by papatel, Nov 7, 2007.
  1. papatel
    papatel Member
    Hey guys I just had a question on how difficult it is to install these parts myself. I haven't done any of them before:
    3 inch turbo inlet (will it fit ok? or do I need to mod crap)
    fuel pump
    Injectors
    20g turbo (3 inch inlet, internal waste gate, 7cm housing)
    I've heard this stuff is pretty easy except the injectors. How much time should this all take about, assuming nothing is messed up?
    I'm looking to do this sometime early next week.
    Thanks!
  2. wrxin8or
    IIRC you will need to do TGV deletes in order to use a 3inch inlet turbo
  3. pEd
    You'll end up having to pull the intake manifold which will give you GREAT access to do everything listed above, as well as the TGV deletes.
  4. WJM
    I'm watching you patrick....;)
  5. BKiller
    BKiller Active Member
    Sounds like a bunch of work. Just give the stuff to me and save yourself the agony!!
  6. Sharpe
    Sharpe Member
    have fun with those deletes! i know i did!
  7. papatel
    papatel Member
    Thanks for the input guys. Looks like i'm staying away from this for awhile b/c of time and money shortage. I barely have enough for the parts so I don't have a buffer if something goes wrong. I'll wait until the cash situation improves. Thanks again!
