STI springs for a wagon?
Discussion in 'Modifications & DIY how-to' started by RoMe, Feb 26, 2009.
  1. RoMe
    RoMe Active Member
    Would they work 06 STI to 06 92x?
  2. Jake
    not sure. the 92x is the same as the WRX. so tophats would be different. but if you just changed springs it may work. unless the are a wider diameter.....
    king has sti springs on the forester....
  3. Davidwrx
    Davidwrx Member
    I have them on my '02 wagon. I had to get 04+ tophats for the rear. Front was OK as is. I made a 7 mm spacer to help with the saggy butt look. So to answer your question, I think yes. It is fine.
