STI top mount on 2003 wrx
Discussion in 'Modifications & DIY how-to' started by josh booth, Aug 8, 2006.
  1. josh booth
    josh booth Active Member
    Put a sti top mount on my 2003 wrx but did not line up on the left side has any one else had this problem?
  2. jt money
    yes everyone has that problem.
  3. josh booth
    What can i do?
  4. gte123v
    gte123v Member
    enlarge the hole until it fits?
  5. josh booth
    Stupid qustion what will this top mount do for my car?
  6. wrxguy
    wrxguy Member
    more air flow = more power.
  7. jt money
    weel you can leave it loose as some do, or you can get a friend to pull the ic until the hole lines up and you can screw the bolt in.
  8. josh booth
    Yes i know that. Is what i ment like do you know like wow much?
  9. moose
    How much power? Not much, once tuned maybe 5-10whp?
  10. nsvwrx
    nsvwrx Active Member
    7-8 whp but not sure how much he'll get witha the td04
    it really only helps that much witha new turbo .. ie vf39
  11. miloman
    i need to dig up the articles but i remember reading that the STI TMIC increases cooling capacity over the stock WRX TMIC but it doesnt do much for airflow
  12. nsvwrx
    yeah, the airflow is just a s bad in the sti one as far as ive read but colloing is better.. so if you ever get a vf39 ur set!
  13. jt money
    i have to disagree i think the sti top mount does wounders for the td04. milo was making close to 265wtq on this setup.
  14. nsvwrx
    hmm, i havent found too much info on this, will look it up
