sti tranny install in 02 wrx
Discussion in 'Modifications & DIY how-to' started by kingwrex, Feb 21, 2006.
  1. kingwrex
    kingwrex Supporting Member
    hey guys i need al little help.
    i happened to come upon an sti tranny and i plan on putting it into my 02 wrx, what all do i need to do to make it work, i nthink that i am going to need: sti drive shaft, sti cv axles, sti knucklles, sti rear diff. what else is needed and where should i look to get this stuff?
    thanks for the help!!!!!!!!
  2. rolling_trip
    rolling_trip Active Member
  3. sol drums
    sol drums Active Member
    i just replace my clutch on my WRX, had to take the tranny, drive shaft, etc. off... so i pretty much know everything about it...
    but i'm sure what you would need to put in a STi tranny on a WRX...
    are you doing the STi drivetrain convertion???
    did you check on scoobymods.com?
  4. GTscoob
    STI tranny swap will require at the minimum the new 6speed, 4EAT or shortened stock driveshaft, 3.9 rear end (you can get them out of older Legacy Turbos or swap out your ring and pinion, or upgrade to an R180 STI diff), probably new axles, new tranny crossmember, I dont know if the STIs have the same master and slave cylinders but that might be something to upgrade, clutch lines too.
    Doing the R180 swap in the rear requires a lot more work than just swapping in a 3.9 R160. You have to swap out a lot of the rear suspension components.
  5. bigb996
    sounds like a lo t of work
  6. WrxCrazy
    WrxCrazy Active Member
    probely gonna cost alot also.. one of my friends did a sti drivetran conv. for abt 2.4k $$$ and it dont count labor, sti tranny, and spring componants good luck on it, and let me know how it went, i'm thinking of it also.. and over all ur car will thank you for the 6th gear
  7. GTscoob
    That sounds about right for labor costs. I pretty much did the same swap, at least laborwise, but went with an older 5speed STI tranny.
    It's really not a hard swap if you get all the right pieces, the rearend is the big pain with the swap. The DCCD wiring is a PITA also but you can get JDM 6speeds without it (and with various front LSD options). Some of the first 6speeds worked with WRX front axles (rears will depend on your rear end) but some of the new ones use a completely new axle.
