I purchased this STi UP from a member on this forum for $50 last year. Just finally got around to doing the install. As with all UP spool up seems to take a little less time and happen a little earlier. Fit and finish, as it is a factory part, is superb. Plus, it has the heat shield still so I didn't need to spend the extra money to get it coated or wrapped. It also allowed me to retain the lower turbo heat sheet as it has the same bracketing (though a little less wide) as the stock WRX up. All in all, for $50, a great buy! The only thing I would do differently, would be to replace the gaskets on both ends when I did the install. I will have to buy new gaskets and go back under the car in the near future...
