Stock Boost Guage
Discussion in 'Modifications & DIY how-to' started by sti-mike, Jan 8, 2007.
  1. sti-mike
    sti-mike Member
    Has anyone out their installed the stock boost guage mounted on the stearing collumn. If so is it worth the 150 bucks to have it installed ???? Or is it plug and play ???
  2. jonnyboy0150
    jonnyboy0150 Member
    Its plug and play for the most part. But you do need to drill for the gauge mount. You also need to remove the 6-disc changer where the connector plugs in. And you have to tee into the BOV vacuum line and run it through the firewall. Thats about it.
  3. sti-mike
    sti-mike Member
    Thankyou I'll get started on it this weekend...
  4. rexrocker
    +1 on "plug and play" ... no problems installing the stock cup with aftermarket Omori gauge on my '03 WRX.
  5. jonnyboy0150
    jonnyboy0150 Member
    Good luck. Feel free to PM me if you run into any problems! ;)
  6. Mad Mallard
    Mad Mallard the mad mallard
    the one thing i hear is getting the cup on is a pain...
  7. rexrocker
    The hardest part was fitting the gauge into the cup. Otherwise, everything went smoothly. If you're buying the OEM kit, it comes with a template for the 2 holes that you have to drill/dremel into the plastic steering column cover. Tie into the radio harness for power and slide the gauge into the cup. The gauge is a tight squeeze. Use some vaseline. If you have problems, post up.
  8. blindfold
    blindfold Active Member
    I find the OEM boost gauge to be inaccrate and hard to read since it is in large scaled metric unit
  9. rexrocker
    True. +1 for the Omori. It was accurate according to the EcuTek data monitor in the car.
  10. jonnyboy0150
    jonnyboy0150 Member
    Anyone know the best way to turn the factory gauge inside the cup? Mine's a little crooked and it drives me crazy?
  11. Alex
    Here's my DIY writeup from forever ago...
  12. jonnyboy0150
    jonnyboy0150 Member
    Very helpful Alex! I appreciate it!
  13. pEd
    Holy Crap Alex... I remember when you first the above pic way back on the "old-school" wrxatl.
  14. Alex
    Yes, when wrxatl was my personal (and expensive) instant messaging tool :p
  15. sti-mike
    sti-mike Member
    Done, thanx Alex this was more then helpfull ......
