Strange metal on metal noise
Discussion in 'Modifications & DIY how-to' started by crashtke, Nov 7, 2006.
  1. crashtke
    It is not boost specific, sounds kinda like if your brake pads were really low and were just going metal on metal...not a squeek noise, but just the noise of metal grinding on metal. I notice it at idle and when I rev it up in neutral. It is not a hissing noise, but something else. It is coming from the front of the vehicle. I listened at the turbo and it is definitely coming from the front part of the car closer to the pulleys and such...I just can't tell exactly where. I am going to try changing the belts and lubing the idler/tensioner pulley tomorrow and see if that helps at all. The belts are due for a change anyway. I am really hoping I have not spun a bearing or something. It still seems to drive normal...so I am hoping it is not internal. If anyone has any ideas feel free to throw them out.
  2. jonnyboy0150
    jonnyboy0150 Member
    Mine did that a couple times. If you have an air compressor, take an air nozzle and blow in the gap between the A/C pulley and the clutch itself. Blow it from several different angles, both in front and behind the pulley. When I did that, all kinds of dust blew out of the gap. After that the noise was gone.
    Hope this helps man! Let me know if it works out!
  3. crashtke
    Cool, I sprayed that and the tensioner pully today with a little wd-40 as they looked a bit rusty and that seemed to quiet things down a bit. I don't have access to a air compressor but gas station should work, lol. Thanks for the tip!
  4. goixiz
    goixiz Active Member
    clutch is designe dto work with friction (engagement) if you use WD40 (lube) tht may contradict the design - just my 2c
    if you localized the area and put a drop of light oil on it that would work better
    I would not spray wd40 on my brakes when it squeks :)
  5. crashtke
    I hear ya, but it is not designed to be rusty, lol.
