Stripped Allen Keyholes on Stock Endlinks
Discussion in 'Modifications & DIY how-to' started by nygiant, Oct 9, 2014.
  1. nygiant
    nygiant Member
    Dec 25, 2009
    472
    0
    I've had perrin sways for a number of years and I'm just now upgrading the stock endlinks to kartboys.
    I did the fronts without issue but the mother effin rears...the allen key holes stripped on both! So now what options do I have before saying ef it and taking it to all pro?
  2. ~The_Duke~
    ~The_Duke~ Member
    Apr 20, 2009
    704
    12
    This is what I would do.
    Soak it with PB Blaster or WD40, hardcore. I am talkin' like spray wait 2 mins spray again for like 30 mins.
    Then get a slightly larger allen key socket (I wouldnt use an actually cheesy L shaped allen wrench) and a hammer. Insert the larger allen key into the hole with as much force as is needed.
    Then turn the bolt. Dont dislodge the allen key, spray with more lube if needed.
    That should work... Its the same concept as a stripped hex bolt, slightly smalled socket, beat it on, and remove.
  3. nygiant
    nygiant Member
    Dec 25, 2009
    472
    0
    thank you sir. I will that a try this weekend
  4. ~The_Duke~
    ~The_Duke~ Member
    Apr 20, 2009
    704
    12
    Did you have any luck with it over the weekend?
    Stripped bolts are a royal PITA...
  5. nygiant
    nygiant Member
    Dec 25, 2009
    472
    0
    Nope, couldn't even try. I was in a car accident unfortunately. The car is busted :(
  6. ~The_Duke~
    ~The_Duke~ Member
    Apr 20, 2009
    704
    12
    That sucks...
    Everyone ok? Broken parts can be repaired.
    Was that you over by costco in cumming?
  7. nygiant
    nygiant Member
    Dec 25, 2009
    472
    0
    Everyone is ok, thanks much for asking
    And nah, that wasn't me at Costco!
