Stromung Exhaust
Discussion in 'Modifications & DIY how-to' started by SkullWRX, Jul 9, 2005.
  1. SkullWRX
    SkullWRX Member
    Ok, so as a LOT of you probably know I've been looking into exhausts for a while. I'm checking out a Stromung exhaust and the B&B. The two setups I'm looking at are:
    1) B&B TBE (3" pipe) dual tips
    2) Crucial down, Stromung secondary dp w/ high flow cat, and stromung catback with dual tips.
    Which do you recommend? Which size of piping for the stromung if I go that route? Also, what kind of steel is the stromung? I can't find it anywhere... and what warranty come's with it? crucial and B&B both off lifetime... tough to pass up. Does anyone have a stromung I can listen to? I heard the B&B and it sounds really good!
  2. oucatch21
    oucatch21 Member
    i just bought a stromung from scoobyblkwrx... it sounds great, and i still have stock upper and downers.... if you wanna meet sometime next week you could here them then
  3. SonicBoom
    SonicBoom Active Member
    I have a full stomung 2.5 tbe if you want to hear that. I don't know what type of steel it is, once again...I'd call Porter from Topspeed with any questions. As far as diameter, it depends on personal preferance and what you plan to do in the future. If loudness is a concern, 3' is way louder than 2.5'. If you plan to go with a bigger turbo in the future 2.5 can get restrictive so I'd go with 3....
  4. JJang12
    JJang12 Active Member
    I have exactly same set up as #2. Stromung sounds the BOMB!! I can let you hear whenever we meet up. It sounds sooo much better from behind than in the driver seat.
