Stupid Wiring Question...
Discussion in 'Modifications & DIY how-to' started by Greg, Aug 13, 2006.
  1. Greg
    Greg Active Member
    When wiring an amp, what does the 'remote' wire hook into on the back of the headunit?
  2. moose
    Are you hooking it up to a stock head unit?
    If it doesn't have a remote wire (usually blue) you can use switched power (usually red) off the head unit harness.
  3. Greg
    Greg Active Member
    I have a double din screen...
  4. JJang12
    JJang12 Active Member
  5. Greg
    Greg Active Member
    Valor
  6. Trey
    Trey Active Member
    Buy a test light too.
  7. yerrow
    yerrow Active Member
    which valor, i have the 650 TT in my volvo
  8. RamblinWRX
    RamblinWRX Member
    on the back of the HU harness there's a 12v switched(red) a 12v always on(yellow). I dont like to run those as you might blow a fuse if you touch chassis ground. i prefer to use a tap splice on the ignition harness(blue plug by your key, i think it's the white wire with thin black stripe for ACC, go check though) for the remote wire, either that or you can get to it by jamming the wire in the fusebox in the correct slot(ghetto).
  9. Greg
    Greg Active Member
    I have the 650TT also
  10. bigb996
    blue with a white stripe, or the solid blue wire if the white striped is not there.
