Hey guys, Will has a magic trick for installing Whiteline Steering rack bushing. The bushings are $34.95, and we'll install them for $95.00. You know you want them SS
this mod is totally worth it. i've got em and have tracked them BIG difference in steering sensitivity
Scott will this get rid of some of the play in the steering wheel? I want my car to have steering response like the Drift 240 we have. Slightly move the wheel and WHOA! the car turns.
wait so....they fixed it on the 05's? i've never driven a bugeye or otherwise so nothing to compare to.
They put a beefier bushing in on the 05s, yes. Its not enough for me, I want a tighter turning radious and quicker response. I crave more go cart like prowess.
C'mon guys, you know you need this. For any pre-'05 cars, try this; next time you come to a safe corner, note the "delay" between turning the wheel, and the car actually turning. Steering rack bushings are the FIX I promise you'll like it SS
this is on my next modding list. Scott, will this fix "off-centered" feeling of steering wheel after long-hard turning (ex. speeding on highway ramp with little 4wd drift)??
This should improve on the "memory steer." One possible cause of memory steer is the steering rack moving in the mounts. Replacing the steering rack bushings should fix this... SS
o man i thought i was the only one experiencing that problem... good to know that it is normal.. whew
