Tag light troubleshooting?
Discussion in 'Modifications & DIY how-to' started by Sparta, Jul 18, 2008.
  1. Sparta
    So you probably know I have to go to court Monday for a faulty tag light and face a $185 fine for it so I need to get this thing fixed. I swapped the bulbs out and they are still out. Any ideas where I need to target to find the problem? The fuses are not blown BTW.
  2. Jake
    damn, i knew you had a problem with them back when we were swapping your motor, but i didn't hear you got pulled over for them.
    it has to be faulty wiring if the fuses and bulbs aren't the culprit. that or a relay...?? i don't know i HATE electrical work.
  3. Jewels450
    Jewels450 Member
    electrical work sucks, good luck with finding the problem I hope you get it fixed. again sorry to hear about the ticket
  4. FACE
    You should do what Steven told you to do for court...
    Did the harness look ok? Did you dig to make sure there were no brakes in the wiring? IDK Holla at me if yiunwant me to help!
  5. kingwrex
    kingwrex Supporting Member
    i could look at it on sunday maybe, hit me up later
  6. Alex
    Fuse okay?
    I hate the tag lights, they're a pita to remove -- are you sure they're plugged in all the way?
  7. Sparta
    thanks guys, hopefully the weather is decent tommorrow so I can tackle this along with everything else wrong with my car, I'm sure I will be calling people :hs:
  8. oneiguy
    oneiguy Active Member
    Good luck dude.
  9. Sparta
    So the first thing I do this morning to get started is begin pulling the bumper off. What a PITA, especially when all you have to work with is a tiny flat head screwdriver and a 10 mm wrench. Guess what I find when I get it off... unplugged.
    I'm still puting it all back together so hopefully thats the problem.
    Now to jack my own thread-
    I have a boost leak somewhere, would putting a little bit of seafoam in there help pinpoint it? I dont want to completely seafoam my motor just yet because I've got some time before my next oil change. If not, does anyone know or have a fogger I use?
  10. crashtke
    First thing first on that is just to make sure everything is tightened down. Go back through and just tighten all the bolts to the turbo, top mount, etc. The offender for me was always the bov. Swing by your local subaru dealership and get 2 bov gaskets. That helped seal mine better.
  11. SonicBoom
    SonicBoom Active Member
    Did your tag light come on?
  12. Sparta
    yep, all fixed! Hopefully SS drops it tomorrow
