Just registered to check out whats going on in the ATL. I found the site off my Tuners page Scott Seigel of course. This is my 05 and mods list. I personally have done 100 percent of the wrenching, with some help from my friends. Not a shop car by any means, Love it pics and mods list below My names Bryan hello all :wavey: Engine: Garrett gt35r Tial 44mm Waste Gate Tial Blow Off Valve Ultimate Racing Rotated Front Mount Intercooler Ultimate Racing Cold Air Intake Ultimate Racing Up Pipe Ceramic Coated, DEI Black Heat Wrapped Ultimate Racing Down Pipe Ceramic Coated, DEI Black Heat Wrapped Gruppe-S Header Jett Hot Coated, DEI Black Heat Wrapped Top Speed Blow Through Maf Housing Perrin Fuel Rails Power Enterprise 850cc Injectors TGV'S Ported and Bench Flowed to 440crm Hondata Intake Manifold Gasket NRG Dual Catch Cans NGK Iridium 1 step colder plugs PWR Radiator Crucial Racing Radiator Cap Crucial Racing 160% Thermostat Samco Radiator Hoses Watter Wetter Crucial Racing Copper Gaskets, Header,Up,Exhaust AGP Copper Garrett 4bolt Flange Gasket Trans: ACT 2500 Pressure Plate ACT 6 Pad Race Disc Unsprung ACT ProLite Flywheel ACT Throw Out Bearing ACT Pilot Breaing Stainless Steel Clutch Line Brakes: Hawk HPS Pads Stainless Steel Brake Lines Motul RBF600 Suspension: Race Comp Engineering Springs Hardened Strut Mounts Falken rt615 Managment: Ecutec Apexi ACVR Apexi Turbo Timer Walboro 255 Fuel Pump Summit Battery Relocation Kit, Vented, NHRA Approved Exterior: Spec C Lip Jdm Cold Air Induction Cleared Headlights De-Badged Trunk Interior: Defi BF Imperial Boost Defi BF Inperial Pyro Lotek Pod Valentine 1 Valentine 1 Phantom Display
damn nice setup you got there Bryan. So you've got a 35r on a stock block? Can I ask how long you've had the turbo in on it?
