Tanabe SEVEN coil overs
Discussion in 'Modifications & DIY how-to' started by SkullWRX, Sep 26, 2006.
  1. SkullWRX
    SkullWRX Member
    Does anyone know anything about Tanabe SEVEN coilovers? Specifically, are they height adjustable. It's hard to imagine any coil over not being height adjustable, but I can't find any specs... Also, what do you know about the TEAS (similar to the Tein EDFC).... It looks like a good system except if there's not height adjustment.
  2. yerrow
    yerrow Active Member
    it is height adjustable its got a threaded perch
    anyways, thats part of suspension dialing and it would be hard to imagine a thread coliover kit not being height adjustable
  3. SkullWRX
    SkullWRX Member
    Thanks! Do you know what the height adjustable range is? Also, what do you mean by "threaded perch?"
  4. yerrow
    see what the actual springs are sitting on? thats called the perch
    and that perch is mounted to a threaded sleeve (the silver portion under/below the perch) . you adjust the ride height by turning that threaded perch up or down.
    thats where you get the height adjustability
  5. SkullWRX
    SkullWRX Member
    good to know. Can you adjust them while they're on the car or do wheels needs to be pulled to adjust height? Or does that change by coilover model?
  6. calmnothing
    You gotta pull your wheels off. Once you pull them off you unlock the mechanism and rotate either direction to raise/lower the height.
  7. Deke
    Deke Active Member
    edit: just kidding
    So are there any coilovers that you can adjust the height without pulling the wheel? Or while in the car, like edfc?
  8. calmnothing
    not that I know of...
    I mean once you have the initial height set you really wont mess with it, i dont think
  9. mmtasty
    mmtasty Active Member
    That's a pretty big typo all over that ad... "Change Dampening Settings..." Ummm... So you can change how wet you want your suspension??? :rolleyes:
  10. socrates42
    socrates42 Member
    they only in car ride height adjustment is available only with the praxis air suspension. they have it at tire rack if you are interested.
  11. mmtasty
    This too:
    More importantly when you have the ability to adjust spring preload on each corner you should balance the weight distribution between R/L sides. Get the height you want then find some corner scales.
  12. miloman
    it isnt a typo... dampening can allow you to change the setup anywhere between severely underdamped, critically damped and severely overdamped (springs allowing obviously)... basically determines how stiff the ride gets by dampening the spring oscillations
  13. yerrow
    only with praxis can height be adjusted. neither teas nor edfc has the ability to adjust height from within the car
  14. FTZ
    If you are interested in the Praxis, one of the guys here has them. He doesn't post much, but he is at every Auto X. His name is Chris, drives a Blue WRX, always wears a Trenchcoat. Really nice guy. If you want to check out his suspension set up, let me know and I will get in touch with him.
  15. Deke
    Deke Active Member
    Yeah I remember seeing him at an auto-x a while ago. He was working the sign-in. I am a little interested, but definitely don't have the money for it so don't worry about it.
  16. calmnothing
    how much does it cost? and wouldnt it weigh more cause of the air bsetup?
  17. Alex
    You could always just solve your problem and buy my JICs :D
  18. Deke
    Deke Active Member
  19. yerrow
    the best bet!!!!!!!!!
  20. calmnothing
    Holy crap.....that is fucking expensive.......
    As it is now it only takes me 5 min to adjust all 5 dampers....and there's rarely an occasion i'd jack up the springrates that high....i'm already riding around like ~450lbs and ~360lbs front and back.
  21. Alex
    Ive been for a few rides in his car and the air bags are fun :D
  22. SkullWRX
    SkullWRX Member
    I bet they're awesome but they're too expensive for me...
  23. mmtasty
    It's like you got me, but you didn't at the same time. Notice what I was pointing out.
    Dampen=to make wet
    Dampening=the act of making something wetter
    Damp=to reduce the amplitude of oscillations of an oscillatory system
    Damping=the act of reducing the amplitude of oscillations of an oscillatory system
    EDIT: I'm a nerd.
  24. calmnothing
  25. miloman
    its also used to stop oscillations in musical instruments
    http://en.wikipedia.org/wiki/Dampening
  26. calmnothing
    I wonder if wikipedia is a legal source.....hmmm i'm gonna starting citing wikipedia in my papers for school
  27. mmtasty
    hahahaaaa... i hate work cited pages...
  28. Deke
    Deke Active Member
    I believe that wikipedia is kind of known for misinformation. I mean the majority of the stuff is correct, but isn't it just stuff that people submit?
    All hail the almighty thread jack!
  29. mmtasty
    LOL... yeah... sorry.
  30. SkullWRX
    SkullWRX Member
    i watched some people get burned on a presentation because they cited Wikipedia... I don't recommend it for anything but trying to understand the fundamentals of what you're writing about. I've never had a single teacher allow it as a source, although I've seen lots of people try to use it.
  31. miloman
    i use wikipedia a lot for my research... and they even give citations for sources... i agree that not everything is legit but if ur looking for real theoretical and technical stuff, thats usually been pretty good in my experience
