hey guys, trying to chip an old mobo socket A. are the palomino and thoroughbred cores interchangeable? the mobo only supports XP2000 athlons but doesnt get more specific in the manual....
http://www.anandtech.com/printarticle.aspx?i=1635 the pins look the same.. but i doubt they they are intercvhangeable.. the t-breed = less v than the older /biggerer pal
hey kan give me a few mins and ic an look up verything for you Four 184-pin DIMM sockets support PC1600/PC2100/PC2700 DDR DRAM modules Supports DDR333 unbuffered DRAMs up to 2GB and registered DRAMs up to 3GB Supports AMD-K7 Athlon /Athlon XP Socket A 200/266MHz FSB Processors Supports AMD-K7 Duron Socket A 200 MHz FSB Processors Going where no manufacturer has gone before, Abit latest line of motherboards, the MAX series, is taking a bold step into attempting to get rid of legacy devices. The first board to receive Abit’s so called “MAX” treatment is their AT7. Based around VIA’s latest and greatest AMD based chipset the KT333, the AT7 provides support for AMD’s Athlon XP (Palomino), as well as upcoming support for AMD’s Thoroughbred based processors.
win. the pdf of the manual doesnt say, and I kept getting routed to a Taiwan website everytime i tried. Domo arigato mr roboto
That board should support barton cpu's as well....check the forums at Anandtech.com btw I have a 2500+ barton for sale if you're interested
oh, dont mind my geekiness showing thru. Its short from "The other day I won at the internet. The last guy was hard." Shortened to "I win" or "win" whenever something good is posted.
