Tein Flex questions for 06 sti
Discussion in 'Modifications & DIY how-to' started by DustySTI, May 22, 2007.
  1. DustySTI
    DustySTI Member
    My last set of coilovers (ground control/tokico combo) were on a honda, so forgive me for any newb like qualities in this post. I just installed the tein flex coilovers on my 06 sti. I did some research, but didn't quite find out what i was looking for. I know the the top perch is for adjusting the height, and i believe from what i have read, the bottom one is for adjusting the compresssion and rebound. I did a about a full turn tighter on the bottom than how they were shipped to me. While installing i had no clue what the bottom spinner was for so i just tried to tighten it. I was too excited installing the coilovers to realize i was an idiot. If someone could just point me in the right direction. Thanks.
    Can anyone tell me where the bottom one should sit?
    Do i measure from the top perch to the bottom or should i let a shop adjust it?
    Anyone recommend a certain place i should go to adjust everything (height, compression, alignment etc.)
    The height from the car from the fender to the center of wheel is 13.5 in. for the front and 12.5 in. in the rear. I have read a good combo is 14 for front and 13.5 in rear.
    Is the current setup i have now too low in anybody's eyes?
    Thanks for the help guys.
  2. WJM
    Ummm...bring it up here to SOG and talk to me/Scott.
    Me=Will in real life.
  3. Alex
    WJM and SS will definately set you up with a "set it and forget it" setup :)
  4. miloman
    Sup Dusty.
    WJM set up my Flex's at SOG with a corner balance and alignment. The car handles better than it ever did. I strongly recommend him.
  5. kingwrex
    kingwrex Supporting Member
    hey dusty, go over do sog and get the corner balance alignment, you will not regret it. money well spent. i plan on getting mine done when i get my whiteline coilovers on.
  6. Strayen
    Strayen Active Member
    Yup, WJM worked on my flex's balance and alignment and I have no problems.
  7. DustySTI
    DustySTI Member
    Thanks guys for the input. I went to topspeed and they adjusted everything for me and corner balanced it. I got my alignment done by Jeff at Tires Plus on Sandy Plains. He was awesome and set it up for street use and made it easy for me to adjust at the track (camber wise). I still have to go to SOG to get some other things worked on and i will let them check it out to see if everything looks ok.
  8. FACE
    you have to come take me for another ride man!!!
