TEIN S.TECH Spring
Discussion in 'Modifications & DIY how-to' started by josh booth, Dec 21, 2006.
  1. josh booth
    josh booth Active Member
    I am looking to put new springs on my 03 wrx. TEIN say 2.0 inthe front and 0.7 in the rear. Does the front sit way lower then the rear? Does any one have these on there car and a pic a can see.
  2. clemsonscooby
    clemsonscooby Active Member
    The S techs are definitely for looks and not performance. The front drop is really low. Its a lot more than you need for an even drop for the front and rear. The front sits higher than the rear.
  3. rexrocker
    Definitely expect the "slammed" look...IMHO, I'd check out some springs that will give you some performance increases (Prodrives, Espelirs, etc.)
  4. josh booth
    I have Prodrives now i want more drop.
  5. clemsonscooby
    Get the Tein Basic coilovers. You can make the drop whatever you want within reason. Its the least expensive Tein coilover on the market. It doesn't have camber plates, but you can still use camber bolts to get OE alignment. Thats a better option than any spring out there, especially since you still have stock struts.
  6. josh booth
    True.
  7. Alex
    Whats your budget?
  8. josh booth
    $300 plus i need to sell my prodrives.
  9. clemsonscooby
    If you can sell your prodrives for a little over $100, $400+ could get you really close to a set of used basics. Just watch the forums and be patient. This way you will have a much better strut also. It will dampen out that higher spring rate and lower ride height. Just make sure you do some research about installing them properly.
  10. josh booth
    Thanks man. :sx:
  11. josh booth
    Is anyone on here running PERRIN lowering springs?
  12. 1ll-WRX
    I love my S techs.....but if you have the money, coilovers will be a better choice...I like the front being lower than the rear...
  13. josh booth
    I know you saw my car at nopi. I just want it to be lower. The prodrives are just not cutting it.
  14. calmnothing
    Ground control springs might be a good option. Height adjustable springs and you can order any springrate you want. THought for the price of ground controls and struts you might as well get soft coilovers.
