the black box
Discussion in 'Modifications & DIY how-to' started by awdlaunch132, Oct 4, 2007.
  1. awdlaunch132
    awdlaunch132 Member
    S ive been having an issue with my windows not working and the breaker at the fuse box clicking. after a few relays and hours with a voltmeter i finally discovered the problem. there is a black box just to the right of the fuse box with two harness plugs facing up plugged into it. if i unplug on of the harness's my powerlocks don't work and my keyless entry does not work. but when i do this my windows work fine. Does anyone know what this box is called. I think it my be something like a s-ecu or something similar. terrible description i know!! any ideas will help. i will try to post pics tomorrow if no one can figure it out. (also i have been looking at the manual for a while and cannot find anything for it.)
  2. Ben@TTR
    Ben@TTR Member
    There is a keyless entry module above the drivers kick panel and an integrated module to the left of the steering column with a grey and blue plug in it. I'm not sure which it would be but those are the names of the two modules.
  3. Ben@TTR
    Ben@TTR Member
    Here are the window wire colors and locations if it helps. Good luck.
    LF Window up/dn blue/red - blue driver window switch in door
    RF Window up/dn black/blue - red/blue driver kick, door harness
    LR Window up/dn blue/yellow - green/yellow driver kick, door harness
    RR Window up/dn green/white - blue/white driver kick, door harness
  4. awdlaunch132
    awdlaunch132 Member
    the one i am describing is the integrated module... i am pretty sure anyway. thanks for your help!!! now i just have to find one and then i am set!!
