The dynamat.. it hurtses usssssssss
Discussion in 'Modifications & DIY how-to' started by moose, Apr 7, 2006.
  1. moose
    Just got done dynamatting my passenger side door. Didn't take more than an hour or so, but god damn I got a crap-ton of cuts (small ones, like paper cuts) on my hands from the thin foil-like layer on it.
    Well worth it though. I used the Xtreme stuff which is pretty light weight and pliable (much nicer to install than original dynamat). Door closes more solidly, lots less road noise and vibration and crap. Speaker sounds more solid.
  2. Brian
    Brian Active Member
    I've been thinking about this. Which areas are you dynamatting? Which make the most difference?
  3. pEd
    all this stereo talk makes me think that a wall of 15's may be in your future??
    j/k
    are you using the real dynamat or the cheaper stuff??
    My neighbor wants to get some done and is looking at the cheap stuff.
  4. rolling_trip
    rolling_trip Active Member
    cheap stuff works pretty good, i still have about a roll and a half in my closet
  5. calmnothing
    You guys want to know a secret? For $50 you can get enough mat to do 2 entire cars. At Home Depot they sell Weather Mat. It's basically the same stuff but in giant 20 pound rolls. It's made for roof insulation. With my old L I did the entire car including floor, ceiling, B pillars, trunk, firewall, and doors. Cost me $25 and like 6 hours.
  6. lostinthewoods
    Ped you still need a stereo :)
  7. yerrow
    yerrow Active Member
    i just dynamatted my volvo's doors today while i installed my new double-din headunit, coax's in all doors and my 12/amp combo. i would have rather used hushmat or raamat because of cost but the original will do, it just costs alittle more. sounds good though
  8. ShaneSTI
    ShaneSTI Active Member
    very interesting. i will looking into that. thought of insulating my STi since its rather noisy stock as ya'll know. thanks for throwing that out there. i'll keep that in mind when i get back.
  9. moose
    Front doors for now. Will probably add some in other areas. Trunk, rear doors, roof, floor would all be good candidates.
    Nah, I went for the premium stuff. Dynamat Xtreme. It's thin, not very heavy, and very easy to put on. Old school and cheap stuff generally involves heat guns, cursing and general hassle. Other than cutting the shit out of your hands this is a pretty easy install.
  10. Mad Mallard
    Mad Mallard the mad mallard
    actually, the wheel welss are also a good place... lost of road noise from tires
    oh, and B quiet is also good mat
    www.bquiet.com
  11. GTscoob
    I think there was something called Brown Bread that kids at my old high school used to use. It was some spray insulation that worked really well and was pretty cheap.
  12. bigb996
    i surrounded my speakers with it but it weighs so much if you do the whole car it gains you a lot of weight.
  13. Mad Mallard
    brown bread, by BQUIET. ;p
  14. moose
    Alex over here at Moose's. He is using the dynamat xtreme, Ive held it, and it really is not all that heavy, just picked up aout 2sq ft sheet and it prob weighs at most 2lbs. The old dynamat is HEAVY, but that's oldschool, this is the new school :eek:
    So, in total, 3-5sq ft. per door x 4 doors + 4 sq ft for spare tire well = 16-24lbs additional weight for a car that is damn near silent on the highway. We just drove back up from the Master's, its by far quieter than my STi.
  15. Brian
    Brian Active Member
    Nice. I'd like to see this done at an install day. Do the doors panels still look good after reassembly?
  16. moose
    There's no visible difference, period.
  17. WrxCrazy
    WrxCrazy Active Member
    they are kinda all same but the company that makes them.. i used dynamatt in my old car, it worked fine, my friend just installed some cheap stuff and it worked fine and quiet
  18. Ayrton
    Ayrton Member
  19. JJang12
    JJang12 Active Member
    I was thinking about putting RAAMmat. will 1 roll (62.5 sqft) be sufficient for whole car??
  20. Ayrton
    Ayrton Member
    I used 90% of one roll for just the chassis. If you are careful, you could knock out the whole car with one roll. I ordered two rolls, and plenty of Ensolite for mine.
  21. goixiz
    goixiz Active Member
    sure its the same stuff ?
    does it have micro fibers that cause lung problems ?
    I know everytime i go in the attic to do something i itch for days. till the last time i wear a painters nylon jumpsuit but sweat like a pig in it
  22. Ayrton
    Ayrton Member
    I am sure it is asphalt based roofing paper. Not really what you want in a car, unless you like the smell of fresh asphalt.
  23. Alex
    The itching is the fiberglass in your lungs and on your skin ;)
  24. moose
    So the secret is that Dynamat Xtreme is just rebadged Home Depot stuff? :rofl:
  25. Brian
    Brian Active Member
    Isn't the xtreme the better polybutyl stuff?
  26. moose
    http://www.dynamat.com/technical_specs_dynamat_xtreme.html
    Weighs .45lbs/sq ft too. The bond strength is about 5x greater than original Dynamat stuff; trust me, it STICKS. (Alex can attest!)
    Wanted to add this too:
    Original dynamat has an acoustic loss of 0.08 at +68 degrees.
    Xtreme has an acoustic loss of 0.417 at the same temp.
    So the original converts 8% of vibrational energy to heat; Xtreme converts 42% !
    The differences are less at colder temps, but Xtreme is still far ahead (.240 at 32F vs 0.16 at 32F).
  27. Alex
    Yep, how did you guess!
  28. Ayrton
    Ayrton Member
    No.
    Home Depot = asphalt based roofing paper (also known as B-Quiet Extreme, Brown Bread, Dynamat Original, eDead v1, eDead v1SE and FatMat)
    What you want is a butyl based product.
    Second Skin Damplifier, Damplifier Pro, Dynamat Xtreme, and RAAMmat.
    http://www.sounddeadenershowdown.com/
  29. moose
    My sarcasm emitter must be broken. :(
  30. Alex
    Sure is :slap:
  31. Ayrton
    Ayrton Member
    Sorry it may be my detector. :hsugh:
  32. Mad Mallard
    neat site.
    minor correction, B-quiet is actually a butyl composite. B-quiet Ultimate is just a higher percentage.
    and also moose, B-quiet ultimate is only .02 less on the Acoustic Loss at that temp, and costs alot less...I think I'll be sampling them against my last dynamat purchase and sharing with everyone.
    http://www.b-quiet.com/compare.html
  33. moose
    I'll be interested in hearing your results. FWIW, their $ comparisons are a little off; notice how they base their price/sq ft on "150+" square feet ordered. :)
    Looks like 50 sq ft is $130 + shipping for around $140. I can find Dynamat Xtreme for $120 shipped for 36 sq ft. So $2.80 vs $3.33 for me... not a huge difference.
  34. WrxCrazy
    dynamat X is what i wanna go but can sum1 post a picture of how to install it in front doors.. cause the stock plastic and tar is there and the controls for auto door locks and how do i install it in there do i skip the doors and locks and just go taking out plastic and tar first.. i mean can sum1 explan how to do this so i can start on it?
