The perfect example why HID kits are a waste...
Discussion in 'Modifications & DIY how-to' started by Alex, Sep 4, 2007.
  1. Alex
  2. Deke
    Deke Active Member
    Lol, nice find. I like how they compared the hid to the halogen just so you can tell how much glare it really puts out.
  3. blindfold
    blindfold Active Member
    10th street JDM's newest sale!
    labor for retrofitting any year subaru is only $19.99, hurry while supplies last!
    [​IMG]*
    *special offer only avaliable through streetneeds.com
  4. savsuby
    savsuby Member
    I was going to buy some HID's but after I talked to you when you were doing my headlights I decided not to buy them. Thanks Alex
  5. Nitro
    Nitro Active Member
    interesting........
  6. BrianGT
    HID kits are awesome if you have projectors... if you just modify the H1/H4 bulb socket to fit a D2S bulb for non-projectors (IE civic), and give you a hella cheap HID setup that is kick ass for the driver, but blinds all oncoming traffic.
  7. Alex
    Maybe its just 10th Street propaganda :naughty:
  8. Nitro
    Nitro Active Member
    Purpose of propagandism
    The aim of propagandism is to influence people's opinions or behaviors actively, rather than merely to communicate the facts about something. For example, propaganda might be used to gather either support or disapproval of a certain position, rather than to simply present the position, or to try to convince people to buy something, rather than to simply let them know there is some thing on the market.
  9. Eco Auto Clean
    Eco Auto Clean Active Member
    no HIDs for the legacy..because I know when I see HIDs in the review now...I always say "oo this may be fun"...as I'm sure thats the whole policeman's look out on it now as well..so stock bulbs I shall ride..don't get me wrong..i love the look of hids....but just not what I'm wanting to do anytime soon.
  10. Nitro
    Nitro Active Member
    chickenshit!!!:rofl:
  11. schneid
    schneid Member
    I am confused...
    how many people on this board work for 10th St. JDM? Alex, I assume...blindfold too? Who posts under the 10th St. JDM handle?
    Just curious.
    Also, since we've cleared up that universal hid kits suck in headlights not designed for HID, how much will it cost me (total) to have 10th st. put s2k hids in my car? (bulbs, ballasts, harnesses, labor, etc.) ?
  12. MrCoffeeATL
    MrCoffeeATL Member
    wait, you can get the S2k lights with out buying an S2k? ;)
  13. Nitro
    Nitro Active Member
    http://wrxatlanta.com/forums/showthread.php?t=10006 :)
  14. baddriver
    baddriver Active Member
  15. Alex
    10th Street JDM is one person, myself :) Any other posts you see are either jokes (blindfold) or various images from LightWerkz, etc.
    Schnied, I sent you a PM about your lights.
    FkU, w/ a quality retrofit very few can actually tell that your lights have been reworked. HID kits are a dead giveaway, you are correct.
  16. socrates42
    socrates42 Member
    19.99 for a retrofit? wow! I'll take two!
  17. baddriver
    Yeah HID,s behind the right projector lens at the right position are fine, but those nuts that put them in front of standard halogen reflectors blinding oncoming traffic make others wanna whip a tire tool out and "modify" their setups.
  18. FACE
    yeah I am glad i got mine stock...just wish they would shine higher on the horizion.....
  19. baddriver
    Me too,
    The beam pattern is a little low at the highest setting.
    How about a group buy on off road lamps!!
    (talk about hammer magnets)
  20. Alex
    You could always adjust them, but I wouldnt recommend that :)
    What 10th Street sells is simple: OEM ballasts, OEM Projectors, OEM Bulbs (D2S), Complete Custom Plug-n-Play Harnesses. 10th Street does not offer HID kits or any other rebased type product. Now, if you own an HID kit and are looking for a retrofit you could reuse your HID kit ballasts and wiring harness with a bulb adapter for a D2S bulb.
    D2R is a high intensity discharge bulb for reflector based housings (eg 2004-2005 STi)
    D2S is a high intensity discharge bulb for projector based housings (eg 2006+ STI)
    Why are projectors just so damn cool? Even with the factory HID lighting on the 2004-5 STi, the light is still being reflected back into the reflector housing before being thrown forward. With a projector the light is actually being thrown outward and intensified / focused via a lens (like if you were to hold a magifying glass outside and focus some of the sunlight on one point).
    Ill write up a sizeable FAQ for everyone, if you have any questions please let 10th Street know!
  21. Alex
    Its fairly straightforward to aim your lamps further up -- if you feel like they are off (maybe you lowered your car, etc) you can use my guide to help realign them.
  22. schneid
    schneid Member
  23. Alex
    Did you get my PM?
  24. SubiNoobi
    SubiNoobi Supporting Member
    So does anyone know if the projector housing on 06-07 headlight assemblies are the same for STi (HID) and wrx/i (non-HID) headlights? They are both projectors, so its possible that they come from the same assembly line.
  25. Nitro
    Nitro Active Member
    np WOW!!! 277 views:coolugh:
  26. Alex
    The projector is quite possibly different, at the very least the bulb holder is different :) But that doesnt matter, we can scrap the stockers and throw some TSX in there!
    They all come off the same assembly line, take the 04-05 sti and wrx lamps. The actual housings (not reflector housings) are basically the same inside and outside except that the HID housing has a small peg inside to guide the igniter wiring and a hole in the bottom to allow the igniter wiring to pass from the ballast through the lamp to the back of the bulb. The high-beam portion of the reflector housing (chrome shiny piece) I'm sure is identical, however the low beam portion is different. It will be designed for halogen OR xenon, end of story. There is no mixing the two (hence this thread, the video and the rest of the comments -- HID kits are a no no).
  27. socrates42
    socrates42 Member
    that 19.99 deal, what does it include, its actually in my price range.
  28. Nitro
    Nitro Active Member
    lol..........a decal:rofl:
  29. Alex
    Consultation :wiggle:
  30. wrxin8or
    he will tell you for 19.99
  31. socrates42
    socrates42 Member
    Damn i thought it was something I could actually get.. oh well... no worries. I am surprised no one has responded telling me to register for Subaru challenge. I swear they are stalking me!
  32. wrxin8or
    sign up for the suby challenge
  33. Nitro
    Nitro Active Member
    suby challenge
    :keke:
