This Looks Pretty Cool
Discussion in 'Modifications & DIY how-to' started by Electioneer, Jul 30, 2012.
  1. Electioneer
    Electioneer Member
  2. lucky13
    lucky13 Member
    Looks cool and seems like its almost fail-safe. Almost.
  3. Electioneer
    Electioneer Member
    That's the one thing that makes it unattractive. The possibility of it draining your oil by itself.
  4. goixiz
    goixiz Active Member
    been on every car i owned 10+ years never had one failed.
    Get the one with the nipple for attaching a drain line - straight into drain pan or if you want to sample your oil in between changes.
    p.s. if you are concerned just put a cap on it so the lever cant turn
  5. b reel
    it's a turbo Subaru, I thought you only add oil and just change the filter.
  6. techlord
    I personally wouldn't use it. I had one and road debris almost pushed it open. Maybe if they've changed the design but that looks exactly like the one I had.
  7. crazyazn
    I've got one, it looks like the one in the pic too. Though the lever does sit in a 'notch' of sorts to act as a sort of lock for the lever. However, at road speeds, I wouldn't be surprised if debris could knock it open.
    I've not had a problem with it, but I also still use the oem plastic cover so I guess it helps a little bit.
  8. WRboXer
    WRboXer Active Member
    I have used a Fumoto on my last 3 cars. It is FANTASTIC. Tool less oil change if you dont run your engine tray. Once you buy one and understand how the valve works, it would be extremely difficult for road debris to cause the valve to open. It does not open easily.
  9. integroid
    I have been using one on my Mini Van for the last 5 years without a problem and it is exposed to road debris. I wouldn't hesitate to put one on any of my cars.
  10. CelticPride
    CelticPride Banned
    If you install it 'properly' you shouldn't have to worry about road debris.
  11. SonicBoom
    SonicBoom Active Member
    Had one on my STI for 4 years with no problems.... Saves so much time, makes oil changes a breeze... If you can get one to open from road debris, I question your route choices. What the hell could you run over that would possibly open that valve? I guess if you rally race or something.
