Those that have it, impressions of Apexi AVC-R
Discussion in 'Modifications & DIY how-to' started by crashtke, Sep 17, 2007.
  1. crashtke
    crashtke Member
    Supporting Member
    Jul 28, 2006
    1,816
    0
    After working for over an hour trying to tame my wastegate with this new turbo installed, it occurred to me that it would be FANTASTIC to have gear specific boost such as the AVC-R incorporates. I was curious how people liked this product?
  2. siegelracing
    Aug 19, 2004
    1,553
    0
    I like them a lot. I can normally tune boost pretty easily with Protuner, but the AVC-R is nice for the gear-specific boost.
    Siegel
  3. 1naplay
    1naplay Member
    Jun 1, 2007
    261
    0
    agree, used to have it on my Eclipse and I love it.
  4. crashtke
    crashtke Member
    Supporting Member
    Jul 28, 2006
    1,816
    0
    My problem right now seems to be that if I hit full boost in first then in 5th it overshoots. If I get it steady in 5th at full throttle, then in 1st through 3rd it never comes close.
  5. ScoobyMike
    ScoobyMike OG Mod
    Sep 24, 2004
    2,952
    0
    I'm sure milo will chime in soon and tell ya all about it....
  6. miloman
    Feb 3, 2004
    12,774
    1
    I like it a lot. Some might disagree, but I think it is quite easy to use. I haven't used any others but I have a few minor gripes:
    1) It displays in kg/cm2. You need to mentally convert to psi if you need it (1 kg/cm2 ~= 14.22psi)
    2) I have mine mounted on the dash using the stand provided with the unit and the buttons rattle a lot.
    3) Only provides boost control for 5 gears. This is not a big deal since I have mine set for gears 2-6.
    4) Can adjust desired boost in increments of 0.05 kg/cm2. This translates to about 0.71 psi increments. I wish it had finer resolution.
  7. Alex
    Alex Community Founder
    Staff Member
    Oct 7, 2003
    15,892
    20
    I am quite tempted to install mine and obtain full boost in 1st and 2nd :)
    Other than that, I have little to say about it...
  8. Kokopelli
    Oct 11, 2003
    2,327
    0
    I really like mine. They are also not that hard to use/setup.
  9. baddriver
    baddriver Active Member
    Feb 22, 2006
    836
    0
    The 91 Turbo Legacy came with one. I haven't tinkered with it yet, but it gives me a consistent 11psi.
    (11psi ain't much but the factory ecu and VF11 that's where I'll stay.)
  10. xnoodlesx
    xnoodlesx recovering meth addict
    Sep 15, 2004
    62
    0
    I've had mine for almost 2 years. It's worth it for the sole purpose of tuning full boost in 1st and 2nd. It's equally nice to tune down in 5th and 6th.
    Another nice thing is you can make adjustments when the weather/season effects boost. Example, in the winter you would need to lower your WGDC as not to overshoot desired boost... and raise WGDC in the hot summers when it's not quite making it.
    You can get them new for $400, dont pay anymore.
  11. crashtke
    crashtke Member
    Supporting Member
    Jul 28, 2006
    1,816
    0
    yeah seeing them on ebay for around $375 shipped. I have been trying to see what I can find. Is there NO way to make it display in psi?!?
  12. miloman
    Feb 3, 2004
    12,774
    1
    Not that I know of.
  13. blindfold
    blindfold Active Member
    Aug 29, 2006
    1,596
    0
    it's too JDM to display psi...at least on mine :D
