IS this equal or is it significantly different 12 sqft for $14.62 thats very good price 9709T19 Adhesive-Back Damping Sheet Polymeric Mastic,.070" Thk,.7 lbs/Sf, 32" X 54", Black In stock at $14.62 Each From Mc Master CArr ( i order from them frequently) http://www.mcmaster.com/
hmm, definitely seems pretty similar. I used dynamat to get rid of some of my inside-the-car exhaust note on my mustang. It worked great. From my memory I wanted to say that it was rather pricey so this would definitely be a discount. Eh, I'm not sure about it.
I will order a sheet and will compare If someone has a small strip or a couple inches of various brands or models that i can compare with. Please pm me Ill send you an address if you can mail it to me.
i only have it surrounding my speakers and i think it sounds good. gotta be careful though, i had it causing my speakers to ground out so i had to tape the terminals.
That is correct. Also, there's a rather significant difference between Dynamat and Dynamat Xtreme. The former is a lot worse to install and doesn't perform nearly as well.
