thrid wing break ligth help
Discussion in 'Modifications & DIY how-to' started by impreza, Apr 30, 2014.
  1. impreza
    impreza Member
    i recently just traded my wingless trunk for a sti trunk with a wing that has a third break light.the wing has a plug for the third break light but my trunk wring harness doesn't have the connector for it.any ideas of where i should tap in to to wire it ?
  2. ChrisW
    ChrisW Member
    I'd imagine you'd wire it to the passenger tail light if you wanted it to be on with the headlights, or the passenger break light if you only wanted it to illuminate when you were braking.
  3. impreza
    impreza Member
    i was think of doing the tail light so when i break it lights up.do you know if on the sti it stays on and just get brighter when you break,or if it only lights up when you break
  4. Third brake light is a brake light.Only lights up when brakes are applied..
  5. impreza
    impreza Member
    Ok thanks for the help guy and do you guys know What wire does what because it's a 2 pin plug with a white and green and another one (don't remember the other Color).
