throwing 1312, but flashed?
Discussion in 'Modifications & DIY how-to' started by Mad Mallard, Mar 31, 2009.
  1. Mad Mallard
    Mad Mallard the mad mallard
    throwing p1312, but flashed?
    I have AP1 flashed with stage 2 now, and driving home CEL came on. Got home and the AP say 1312.
    uh, help? I thought that sensor was 'turned off' on a stage 2 map?
  2. GTscoob
    What does a 1312 mean?
    A quick google search shows that one of your injectors is fubared. I dont think thats a CEL you'd want to turn off.
  3. techlord
  4. Davidwrx
    Davidwrx Member
    I thought it would disable it too. Do you have a stock up pipe? If it is gutted / non stock, you could do the resistor trick where the EGT sensor plugs in. I did that when I changed my up pipe at the same time I got an APv1 (I did it in case I ever went back to stock I wouldn't have to deal with that). Just a thought. Maybe worth a call to Cobb if it is a new unit. I have an extra resistor (I think) if you want it but they are only a couple of dollars at radio shack. For the resistor value check out NASIOC unabombers manifesto in the up pipe section.
  5. Mad Mallard
    chris @ cobb is sure i have an old map... reflashing...
  6. Mad Mallard
    not the sort of thing to have come up right when you're about to drive 600 miles...
    ...so far, seems to have worked.
