throwing code p1092 and p0328 Help!!!!!!!!!!!
Discussion in 'Modifications & DIY how-to' started by osborne519, Feb 28, 2011.
  1. osborne519
    osborne519 Member
    i have no clue where to start on the p1092 i know its a tgv but i have no clue how they work or what to do with them
    the other im assuming means i need to replace my knock sensor
  2. Doug@DBW Motorsports
    check the grounds on the intake manifold first.
  3. osborne519
    osborne519 Member
    where are all the grounds
  4. goixiz
    goixiz Active Member
    OP if you dont know where they are i would recommend you visit one of the vendors here or get someone to help you
  5. b reel
    open hood. the front two intake runners will each have black cables directly bolted to them. take wire brush and scrub all of the surfaces.
  6. osborne519
    osborne519 Member
    i know where those 2 are i just wanted to make sure that was it.. ive found a few things missing on this car and wanted to be sure
  7. b reel
    this your wagon right? make sure your posts and cables are clean too.
  8. osborne519
    osborne519 Member
    yeah alls good but still having issues
  9. osborne519
    osborne519 Member
    the last time i had a ground issue, i couldnt figure out which one people were talking about cause it wasnt on my car
  10. b reel
    how long has the car been sitting? With it being cold, oil in the intake tract may have gummed up on the throttle body and TGV butterflys. DO NOT use "carb" cleaner, use TB cleaner that is O2 sensor safe.
  11. osborne519
    osborne519 Member
    switched the motor out still having issues with the knock sensor
