Tighten my rear
Discussion in 'Modifications & DIY how-to' started by oneiguy, Nov 16, 2008.
  1. oneiguy
    oneiguy Active Member
    So went up the past 2 days for a drive. Back end keeps breaking loose to much for me. Tried loosening the rear struts. Still didn't help. I am about to switch tires to Dunlop D1 Star Specs. Here is a list of what I have done. Any advice on what to go with next. I know a bigger front sway is in the works also.
    Engine:
    XS Power Catless 3" Downpipe
    Invidia G200 Catback
    Turbo XS Uppipe
    Cobb Accessport V2 Stage 2
    Suspension:
    Racecomp Engineering Wagon Springs
    Cobb Front/Rear Sway Bars
    Cobb Rear end links
    Hotchkis Front end links
    Whiteline Rear strut tower bar
    Koni Yellow inserts
    SPT H-brace
    04-07 rear top hats
    IXIZ Stage2 Shortshifter
    Wheels and Brakes:
    5zigen Pro Racer GN+ Forged 17x7.5
    Cooper Zeon 2xs tires (I drive 35k -40k a year)
    Power Slot Rotors F/R
    Stainless Brake line
    Hawk HP+ Front
    Hawk HPS Rear
  2. slowwrx
    Whats your alignment specs front and rear
  3. oneiguy
    -1.2 front, -.9 rear
  4. slowwrx
    I would add more camber both front and rear, with Neovas I found that they react well to 2.8 front and 1.6-1.8 rear
  5. slowwrx
    also how much toe are you running
  6. GTscoob
    I'm no racer but I'd say at more camber all around like Matt says. Can you loosen your rear sway bar to a lower setting?
  7. mmtasty
    mmtasty Active Member
    I run full negative front and -1.5 rear. What's your air pressure? You may need to go back to a stock rear sway or maybe just stock rear endlinks. You could be lifting the rear inside tire... and then sliding. Bumpy/banked turns and stiff sways are awkward. Wheel droop and good tires are really helpful.
  8. slowwrx
    He should have plenty of droop travel and the sways should be okay, the rear camber curve on Subarus isn't that bad.
    .9 is not much camber even on a street tire, I would say camber first and try and keep your hot tire pressure around 38-42
