Time for a new clutch
Discussion in 'Modifications & DIY how-to' started by AXLEJOHNSON, Jan 24, 2008.
  1. AXLEJOHNSON
    AXLEJOHNSON Member
    My car has been slipping occasionally in 5th and 6th gear when it is cold outside, so I am sure more is around the corner. I have found the OEM replacement clutch and am pretty close to ordering the flywheel, clutch, pressure plate, and throwout bearing, but wanted any input you guys had on aftermarket or the OEM clutches. Thanks.
  2. WJM
    OEM is fine. Any organic clutch is going to last about the same amount of time as the stocker.
    So if you like the stocker...just fine a cheap ebay organic and go with that.
  3. slowwrx
    There is usally no need to order a flywheel and pressure plate, just replace the disk, unless you are making a lot powere and they are burnt or warped.
  4. AXLEJOHNSON
    AXLEJOHNSON Member
  5. AXLEJOHNSON
    AXLEJOHNSON Member
    I am also going to install a dp and go stage 2 when I do this, would I need a stronger clutch in this case?
  6. AXLEJOHNSON
    AXLEJOHNSON Member
    I am going to order a new clutch disc and throwout bearing, and have my my flywheel resurfaced. Genuine Subaru OEM parts lists one as a Release bearing, is that the same as the throwout bearing? Any suggestions or ideas?
    Description
    Mechanical Catalog - 2004 - Subaru - Impreza
    Clutch, Clutch and flywheel, Disc, Disc, impreza, 4wd, 2.5l, w/turbo
    $95.12
    Clutch, Clutch and flywheel, Release bearing, Release bearing, all models, 2.5l, w/turbo, impreza $100.58
  7. AXLEJOHNSON
    AXLEJOHNSON Member
    I have the clutch disc and release bearing (which I assume is the same as the throwout bearing), but should I get a new release fork and pilot bearing?
  8. WJM
    both bearings, yes.
  9. AXLEJOHNSON
    AXLEJOHNSON Member
    Thanks Will, does that yes include the release fork?
  10. WJM
    no need to replace the fork. It should outlast the life of the car.
  11. AXLEJOHNSON
    AXLEJOHNSON Member
    Awesome, thanks for you help will, much appreciated.
  12. AXLEJOHNSON
    AXLEJOHNSON Member
    I wanted to say thanks to Ped for replacing my clutch this weekend. He did an awesome job the car is running great now. We or mainly he wrestled with my motor for about 2 hours because it didn't want to leave the transmission, apparently it is co-dependent. I think Ped might have made it more difficult to get out of a dinner party that night, but I am not sure....j/k. So I just wanted to say thanks for all his hard work this weekend.
  13. pEd
    pssh.... dinner parties are for sissies :rofl:
    I didn't even get in trouble, which was completely unexpected.
  14. AXLEJOHNSON
    AXLEJOHNSON Member
    Awesome, I thought for sure you were in for a bad Sunday.
  15. Sparta
    Ped is the man!
    Didn't you have a dinner party when you did my clutch too? lol
  16. FRCFED4
    FRCFED4 Member
    must be his thing about changing clutches, dinner party then offer to install clutch
