Time for a new Turbo?
Discussion in 'General Community' started by Berzerklo, Feb 25, 2008.
  1. Berzerklo
    Berzerklo Active Member
    So on my way to work this morning I am on 85 and I start hearing this noise that I thought was static coming from my radio. I just installed a pioneer nav unit yesterday so I figured I just messed up something there. Well, that was wrong. I turn off the radio and it sounds like my wastegate has diarrhea. :eek4: I checked my gauge and I am not getting any boost. There were no CELs thrown. I have not gotten a chance to get under the car to check for shaft play yet, but I am pretty sure it is time for a new turbo.
    I am running a VF39 on the stock 2.0L on an '03 WRX. I am pretty sure I am going to get it replaced with another VF39 unless someone can convince me to buy something else. I was real happy with the the 39 power levels (and the respectable gas consumption because of the lag). Any suggestions on a different setup? Any suggestions on where to take it? I am looking at TopSpeed, Batlground and Lethal Injection at the moment...
    Thanks for your help!
  2. GTscoob
  3. FACE
    Sure you dont just have a boost leak somewhere???
    or should I say hope you just have a boost leak somewhere...Good Luck man!
  4. Kokopelli
    Is the wastegate arm still attached?
  5. Jake
    sounds like a boost leak to me. getting any smoke out the exhaust
  6. dontcallitarex
    dontcallitarex Active Member
    Bump. That bites, man! Sorry to hear it. Glad you got the nav unit in, though!
  7. Berzerklo
    Wow, well it look like I called wolf here. Mike (Liquidforce) just stopped by to take a look at my car during his lunch break. In about 10 minutes he found my EGT sensor had backed out and fallen out of my up pipe. Problem solved.
    Mad props to Mike! I guess I will do more work before I freak out next time...
  8. Matt
    yay!!!
    glad you got it fixed, Scott!
  9. dontcallitarex
    Hooray for cheap and easy fixes!
  10. Berzerklo
    Thanks Matt! But, when the time comes for there to be REAL work done on my car, I think I will call Lethal Injection. I have heard nothing but good things about. Them.
    Hah, I am still getting used to having a boosted car!
