Timing Cover Compatibility Question
Discussion in 'Modifications & DIY how-to' started by ChrisW, Nov 2, 2011.
  1. ChrisW
    ChrisW Member
    Will a timing cover off a ej20h fit an ej205?
    I would assume they would be interchangeable, since 20h shortblocks will work with 205 heads. Any thoughts?
    Thanks
  2. Cory
    Cory Member
    The center section might work but the cam gear covers might not the only way to know for sure is to physically try and put them on.
  3. Kokopelli
    I have some timing cover bits if the ones you have wont work.
