tire size on my 06' wagon?
Discussion in 'Modifications & DIY how-to' started by wagon_dude, Dec 20, 2006.
  1. wagon_dude
    wagon_dude New Member
    Do I need to stay with the OE 215/45-17 or is there a better size? I am keeping the stock wheels. I am planing on spt pinks and a 22mm rear bar. Any suggestions on a long lasting, smooth, summer spec.
  2. calmnothing
    With a 225 tire in the rear you're going to end up rubbing on the fender. Well maybe. The SPT pinks are very stiff springs so they should keep your car from dipping that low and rubbing. And you dont want to do 225 in the front and 215 in the rear as it will eat up your center differential.
  3. Deke
    Deke Active Member
    As well as making you look like you drive a fwd car (which I might add look absolutely hideous when they have slicks on the front and normal tires on the back.)
  4. MarkM2016GTI
    The tire size on my wagon is 225/45R/17. Did you mean to say that?.
    Mark
  5. wagon_dude
    No I did not! Did you buy yours used? Mine came with 215's and TIRERACK'S OE specs will tell you the same.
  6. MarkM2016GTI
    Oh...sorry...I was just trying to help...misunderstood...
    Mark
  7. wagon_dude
    I was not trying to sound rued or anything. Do you like the 225's? What tire do you run and do you like?
  8. SonicBoom
    SonicBoom Active Member
    How wide is the rim on the 06' wagon? My WRX had an 6.5 inch rim and a 225 would fit but would bulge out like a truck tire... I'd say if the rim is 7" you could do 225 45' no problem...
  9. SubiNoobi
    SubiNoobi Supporting Member
    Is that on a 17x7 or 17x7.5 wheel?
    (I really want to upgrade the 16" rims and tires on my 2.5i wagon, so I am wondering how much extra width I can get without rubbing)
  10. sol drums
    sol drums Active Member
    i'm running 225/40/18's and mine is lowered. i was scrubbing on the fronts but i raised the suspension about 1/2'' and it's fine now.
  11. UBAR
    UBAR Member
    Just go down to a 40 side wall and run 225, the 40 should go well with th pinks and should not rub! I have 225/45/17 for day to day and 245/40/17 for race season!
