TopSpeed - Control your BOOST! HKS - Hallman
Discussion in 'Vendor "For Sale" Classifieds' started by TopSpeed, Sep 16, 2009.
  1. TopSpeed
    TopSpeed Member
    Accurate HKS electronic boost control at an affordable price
    The EVC-S features a solenoid valve specifically designed to accurately control boost pressure up to 250kPa or 36 PSI, 2 boost level settings as well as settings for offset and boost response. Also included are: overboost warning with drop boost feature; peak hold boost readings; after-image display; data lock and an internal diagnostic function. Designed to be compatible with both internal and external wastegates, the EVC-S also complements the current HKS Turbo Timers and AF Knock Amp.
    Functions and features of the EVC-S include:
    • Affordable model of the HKS EVC series
    • Specially designed solenoid valve for boost control function
    • Compatible with internal and external wastegates
    • Junction connection system allows display unit, solenoid valve and boost sensor to be directly connected to the control unit enabling an easy installation.
    • Display unit is the same design concept as the latest HKS electronic products and is selectable from kPa to PSI
    Easier installation
    • Each unit connects independently to the center control unit which processes all signals
    • Thin display unit enables free layout
    Unified Design
    • The same design as A/F Knock Amp. and other HKS electronics
    • Unified design for whole HKS electronics product line-up
    Price conscious model with specific functions
    • 2 control modes (A/B mode)
    • Basic parameters Offset, Response Control range of solenoid duty output = 0 - 100%
    • Warning, Drop boost functions
    • Peak hold, After image display indication functions
    • Applicable for both internal and external wastegate types
    • Factory boost function when power is off
    • Data lock function
    • Diagnosis function for malfunction of boost sensor, solenoid valve or wiring connection
    Retail: $375.00
    Your Price: $329.99
    Thanks for looking!
  2. TopSpeed
    TopSpeed Member
    This is pretty much the best MBC on the market.
    Kit Includes:
    Hallman Pro Valve w/ ceramic ball, light and heavy springs included, 3 feet of vacuum line, mounting bracket, hardware kit and specific installation instructions.
    Key features:
    Billet Aluminum, Anodized, Laser Engraved. Ceramic Ball and light spring for excellent control of boost up to 5 psi over stock boost level. Heavy spring also included for adding more than 5 psi over stock. Currently, BLACK is the only color I have available. Can be upgraded to cockpit control with additional add-on kit.
    Retail: $110.00
    YOUR PRICE: $99.00
    Order yours today!
  3. TopSpeed
    TopSpeed Member
  4. TopSpeed
    TopSpeed Member
  5. TopSpeed
    TopSpeed Member
    to the top
