TopSpeed Inc. AMS GT30R\GT35R Turbo Kits (you can only buy them here)
Discussion in 'Vendor "For Sale" Classifieds' started by Matt@Topspeed, Sep 1, 2010.
  1. Matt@Topspeed
    Matt@Topspeed Member
    We are now the exclusive dealer for the AMS GT30R and GT35R turbo kits.
    As some of you may know AMS no longer produces their turbo kits with Garrett turbos. We here at TopSpeed Motorsports feel that there is still a market for this tried and true turbo. Therefore we have worked an exclusive deal with AMS to bring back the GT30 and 35R.
    These will be available only through TopSpeed Motorsports. The quality of the AMS turbo kits is simply amazing.
    In our opinion, there isn't another kit on the market that even compares.
    We tested some of the first kits with AMS, and can tell you that they perform great. Fit and finish is amazing, spool and power are honestly as uncompromised as it gets. Our owner and tuner Doug Wilks has one of the first 08+ 35r kits on his car. The car makes 492whp and hits full boost @ 3700RPM (see graph below)
    The AMS Subaru Rotated Mount V-band Turbo Kit is the new benchmark in Subaru performance. Designed to meet the demanding needs of road race, drag race and street cars alike, we have successfully achieved unparalleled drivability, response, and horsepower. Our unique design has been tested and refined for over 1 year to provide reliability, OEM like fitment and options never available in a Subaru turbo kit before.
    The AMS kit brings some new ideas to the table…
    •V-band housings
    Each AMS Subaru Turbo Kit incorporates the latest V-band exhaust housings with options for .63, .82 or 1.06 a/r. The Tial Turbo V-band housings not only provide the most horsepower and save weight but they eliminate the need for gaskets and are easier to install. No more annoying exhaust leaks and no gaskets to replace!
    •Intake Pipe Solutions
    While a unique 3” cold air intake pipe is standard we also provide an option for pull-through or push-through MAF applications.
    •Cast Stainless Steel V-band Up-pipe
    Implementing CAD and Casting designs we are able to produce not only an extremely strong and reliable piece but one that is not limited to the restrictions of a hand fabricated up pipe. Smooth transitions, optimal pipe diameter and solid construction make the up-pipe another key component to the AMS Subaru Rotated Mount Turbo Kit.
    The AMS 30\35R is the perfect choice for street, road race and drag racing and are great all around turbos on pump gas.
    Each AMS Subaru Rotated Mount V-band Turbo Kit is hand built here at AMS with a meticulous attention to detail. We know what it’s like to install a turbo kit so we provide all the necessary hardware and detailed instructions for a hassle-free installation.
    On a GT30R kit with a top mount intercooler, fuel and exhaust upgrades we were able to put down 485 whp and over 500 ft. lbs. of torque! This same simple combination netted an 11.3 quarter mile time in a full weight 2007 STI on stock tires!!!
    Features
    •2” ID rotated V-band cast stainless steel up-pipe for optimum flow and durability
    •5/8” thick flange on up-pipe to ensure a proper seal
    •Turbo support bracket maintains turbo kit reliability under any condition
    •304 stainless steel TIG welded construction
    •Lifetime Limited Warranty on the up-pipe*
    •True Garrett Dual Ball Bearing GT series turbo with ported shroud compressor covers to prevent compressor surge
    •Tial Stainless Steel V-band exhaust housing with choice of .63, .82 a/r ratios
    •Your choice of a genuine Tial 44mm or 38mm V-band wastegate to ensure proper boost control
    •Wastegate feed strategically placed on the Up-pipe for precise boost control
    •10” stainless steel external wastegate dump tube
    •No gaskets needed for the turbo to up-pipe, up-pipe to wastegate or turbo to downpipe
    •Your choice of true 3” cold air intake pipes to suit a pull through or 3” blow through mass air flow sensor intake pipe
    •Bolts up to any stock or aftermarket header that fits the factory up-pipe
    •Downpipe fits AMS & most other aftermarket cat-back exhausts
    •Kit Utilizes 4 ply silicone tested up to 50 psi of boost!
    •New coolant lines for your coolant expansion tank for a clean engine bay
    •DEI heat insulation to protect OEM wiring from excessive heat
    •Kit includes ALL necessary fittings and hardware for installation
    •Class 10.9 fasteners & 4 ply silicon couplers. We use the best hardware and silicone so that it goes together right the first time
    Kit Includes
    •Cast stainless steel Up-pipe
    •AMS spec Precision Turbo GT series dual ball bearing turbo with ported compressor cover and Precision V-band turbine housing
    •Genuine Tial 44mm or 38mm V-band wastegate
    •Integrated turbo support bracket
    •AMS high-flow off-road test-pipe (high-flow steel core catalytic converter optional)
    •DEI Heat insulation for your electrical wiring
    •New lines for your coolant expansion tank
    •Stainless steel 3” downpipe with integrated Stainless steel flex section
    •Stainless steel oil feed line (fittings for both WRX and STI included)
    •Custom AMS stainless steel oil return line
    •4 ply silicone 2.5”” turbo outlet pipe, intercooler and intake couplers
    •Top quality hardware package including nuts, bolts, fittings and clamps
    •Polished aluminum 3” cold air intake pipe with K&N air filter for blow through MAF (pull trough MAF optional)
    •Detailed installation guide
    Options
    •Your choice of .63, .82 a/r exhaust housings (no additional charge)
    •3” Pull through MAF intake pipe (optional) or 3” Blow through MAF intake pipe (standard)
    •High-flow catalytic converter
    Applications
    •2002-2011 Subaru STI/WRX
    •Fits USDM Models (JDM and European Models yet to be determined)
    Purchase these Exclusive kits here
    AMS \ TopSpeed GT30R Turbo Kit
    AMS \ TopSpeed GT35R Turbo Kit
    [​IMG][​IMG]
    [​IMG][​IMG]
