TopSpeed Tuned STI: E85 652hp 545tq!!!
Discussion in 'Vendor Chat' started by Doug@DBW Motorsports, Nov 23, 2009.
  1. Doug@DBW Motorsports
    Today was an awesome day.. after months of emails with a customer of mine walking him though his build he showed up today for the tune. Let me start off with saying for the last few years I have been waiting to have a customer build a suby like this... and finally I got my wish.
    2006 Sti
    Mods:
    Sleeved EJ257 Block
    8.5 to 1 compression
    Carrilo Rods
    K1 Crank 79mm stroke
    1600cc injectors
    Dual Bosch 044 pumps
    GSC S2 Cams
    Cosworth Intake
    Cosworth CnC head 1mm oversized valves
    Custom FMIC
    HTA86 TURBO
    Tial 44mm wg
    AEM EMS (TopSpeed Tuned)
    I am probably forgetting some small details, but thats the engine stuff atleast. When the car got here we pulled it off the trailer and I loaded one of my basemaps to get the car fired up and strapped it on the dyno.
    Impressive to say the least.. I maxed out the 1600 at 32psi @ 7300rpms, otherwise I would have upped the rpms. But next thing on the list is the new 2200cc injectors a larger hotside and a retune for 40psi :naughty:
    Until then here is the final graph from 32psi on E85...
    TopSpeed Tuned FTW!!!!
  2. ZenMotors
    ZenMotors Member
    Nice numbers!
    About time someone starts playing with bigger T3's
  3. Ben@TTR
    Ben@TTR Member
    Thats amazing!! Pics/vids?
  4. Doug@DBW Motorsports
    for realz.. still had the .82 backside on it which is a bit small for this power level. Which is why the power falls off in the higher rpms, or so we will find out when I retune it with the 1.06 hotside.
  5. Doug@DBW Motorsports
    No sorry.. I will make sure to get some video when he comes back.
  6. slowwrx
    Nice Doug, don't see many STIs at that Power Level
  7. yerrow
    yerrow Active Member
    about time someone rings out the hta68
  8. Doug@DBW Motorsports
    Yeah.. but I want 700... lol
  9. wagunz_pwn
    Wirelessly posted (From Your Mom's House)
    post reserved for Coolrex to leghump!
  10. b reel
    ^^^question is, where's Jake?
  11. oneiguy
    oneiguy Active Member
    lol
  12. nicad
    think the HTA is worth the money?
    and would you recommend sleeving a block with that setup? or would the factory liners take the abuse?
    these questions are relevant to my interests. :banana:
  13. G-Man04sti
    G-Man04sti Member
    Must be nice to have those ponies under the hood!!!
  14. Doug@DBW Motorsports
    Factory sleeves are good for 26-28psi, anything more than that and they will oval. In drag race situation you can run them at 30-32psi for short burst on the factory sleeves but not sustained. In any event if you really plan on making big power (ie: over 600) you need to sleeve the block.
  15. Cool_____
    My leghumping is reserved for instances when crappy tunes are made better ;) This one is good from the get go.
    That's impressive Doug. Is this the highest hp Suby you have done to date?
  16. Nice. Sounds like a beast.
  17. onemoresti
    onemoresti Member
    650whp must be insane to drive! Is this a dedicated race car or is it running around the street somewhere?
  18. Jake
    Not home or anywhere with Internet access. Lol.
    Nice job Doug
  19. Matt
    I can't remember if Dan Lowman's STi made more power or around the same....If he did, that was to the crank, not the wheels
  20. Jake
    I thought Lucy was around 650whp??
  21. Cool_____
    I think Lowman's car was around 620hp. That was ages ago so I don't quite remember. Lucy was a dedicated track car but power is power. Regardless I'm very impressed with this powerband and how smooth and progressive it is. It's not like WHAM boost HOLD ON FLUX CAPACITOR ACTIVATED! It's s nice progressive pull when means it'll do a much better job putting the power to the pavement....although I bet it still LIGHTS up the tires.
  22. Doug@DBW Motorsports
    Dan's car made 606.. IIRC and i never dyno'd lucy on the kill map. However she did make 580whp @ 26psi
  23. Cool_____
    How much boost was Lucy's kill map? It had stock sleeves so I'm gonna say 29-30 psi?
  24. Doug@DBW Motorsports
    Honestly kill map was 28psi.. and only run for one lap. But lucy's motor was a bit special
  25. Cool_____
    I want to ride in this beast of a car!
  26. http://www.youtube.com/watch?v=LRXhiKKWHoM
    Here is a video of Lucy making 520 on low boost map 24psi...
    not to mention that was on Cobb's "low reading" mustang dyno @ 4400 feet elevation :)
    She was a mean little girl too!
  27. gotsol
    gotsol Active Member
    riding in Lowman's car with Doug made me realize he isn't afraid of death!
    Great tune, I hope the diffs hold out
  28. Jake
    yeah thats what i remember. that, and i think someone said in the same thread on the topspeed dyno on that setup would probly make well over 600hp
  29. UpSideDownDesi
    UpSideDownDesi Active Member
    that makes me happy inside. Great numbers and beast of a car.
  30. Mike@TTR
    Mike@TTR Active Member
    Nice work Doug. Nice flat torque curve!
  31. Cool_____
    Doug you think a Tial hotside would help this setup any?
  32. Doug@DBW Motorsports
    Maybe.. but unless we could test it we wouldn't know for sure.
  33. Cool_____
    Too bad his isn't vband as swapping the hotside's from your 08 to his would be a breeze.
  34. Doug@DBW Motorsports
    yea.. I know the customer is going to swap the .82 housing out for a 1.06 to see if we can gan some topend and loose some exhaust backpressure in the manifold.
  35. Doug@DBW Motorsports
    yummy E85... funny thing is I haven't seen one pump in S. America that sells it.
    *Cough* 2x044
  36. siegelracing
  37. Cool_____
  38. Matt
    I think I'll start watching this....closely
  39. Doug@DBW Motorsports
  40. Cool_____
    Would it matter if it's in a Subaru? One of the charts shows the flow on their test rig of a twin 044.
  41. siegelracing
    It was that test and a long phone discussion with a Bosch engineer that made us pick the Bosch 044's...
    Siegel
  42. Doug@DBW Motorsports
    Does if your talking about being "Innovative" or maybe I too am a Retarded Monkey... lol
  43. Doug@DBW Motorsports
    Cool... we had a set of twin 044's for clarks car that we were going to use to replace the aeromotive pump. But after alot of research and talking with numerous other fuel pump mfgr's we decided to ditch the 044's and run one single weldon. No point of over complicating things with twin pumps when you could just run one pump. Since the aem is turning it on anyway ;) and we all know twin pumps are a dangerous thing since its super hard to tell when one is failing.
  44. slowwrx
    I love innovation especially if it involves retarded monkeys
  45. Cool_____
    Matt and Doug....you guys are too much. :rofl:
  46. slowwrx
    LOL, maybe someone will release a "real" fuel system soon
  47. b reel
    It's spelled "Reel" and as for innovation, unless you have a pump that runs on moonbeams and is variable from mundane to unfreakinbelievable flow, it's adapted at best. Now if you installed a failsafe and warning light to show a pump failure, to me that would be innovation.
  48. slowwrx
    By the time some type of sensor would detect pump failure...your motor is toast
  49. b reel
    Well if you are SLOW I can see that being a problem in your case.
  50. goixiz
    goixiz Active Member
    maybe,
    but if you have a closed loop system it can detect the fuel pressure or flow and throttle the boost or wastegate there is a possibility of saving the engine.
    Twin pumps can be complex but it can also be simple if proper fuel feed to the rails
