FP 68HTA Turbo for the Subaru STi/WRX Everyone has seen or heard about Evo3 16g turbos and TD05H 18g turbos for the Subaru 2.0 and 2.5 engines, our newest turbo is the FP 68HTA™Turbocharger for the Subaru STi/WRX unit which out flows both the E316g and 18g wheels and allows for higher PR operation without increased compressor outlet temperatures like the existing 16g and 18g wheels. Mass flow is increased to a whopping 47lb/min which is several lb/min greater than either the E316g or the 18g wheels are capable of. Rapid spool and large torque numbers are guaranteed by the TD05H turbine section. These units are constructed from Genuine MHI 16g turbochargers which are reconfigured to 68HTA specs by Forced Performance. These turbos come with the inlet and outlet gasket set. YOUR PRICE: $889.00 FP HTA GT3076R Ball Bearing Turbocharger The FP HTA GT3076R turbocharger is based on the world renowned Garrett GT Ball Bearing structure. This fact assures the highest strength and longest service life possible. At Forced Performance, we have long recognized the precision and excellence in manufacturing found in the full line of Garrett Ball bearings cartridges and turbochargers, and this is exactly why we choose Garrett over others manufacturers when we build our custom application HTA units. The 76mm size HTA wheel has 54.8mm inducer and flows over 57lb/min without dropping efficiency, and works well at pressure ratios as high as 4.5:1 . There optional turbine housings for this turbo, but the recommended default housing is the .82 A/R or .63 A/R T31 style with it's compact 2.5" diameter 4 bolt outlet. We have the corresponding gaskets and flanges for this housing if needed. YOUR PRICE: $1679.99 FP HTA GT3582R Ball Bearing Turbocharger The FP HTA GT3582R turbocharger is based on the world renowned Garrett GT Ball Bearing structure. This fact assures the highest strength and longest service life possible. At Forced Performance, we have long recognized the precision and excellence in manufacturing found in the full line of Garrett Ball bearings cartridges and turbochargers, and this is exactly why we choose Garrett over others manufacturers when we build our custom application HTA units. Already have a Garrett GT3582R turbo? Wish it was an HTA™? We can help! For a nominal $600 fee you may send us your complete Garrett GT3582R turbocharger and we will refit it with our 82mm HTA™ compressor wheel and advanced ported shroud cover and perform a CHRA balance after assembly to ensure PERFECT balance and max turbo RPM. YOUR PRICE: $1679.99 FP HTA GT3586R Ball Bearing Turbocharger The FP HTA™ GT3586R turbocharger is based on the world renowned Garrett GT Ball Bearing structure. This fact assures the highest strength and longest service life possible. At Forced Performance, we have long recognized the precision and excellence in manufacturing found in the full line of Garrett Ball bearing cartridges and turbochargers, and this is exactly why we choose Garrett over others manufacturers when we build our custom application HTA™ units. This 62mm inlet / 86mm exducer HTA™ wheel extends mass flow well beyond 75 lb/min with observed power output in the 730+whp range on well prepared cars. This turbo is available with a variety of turbine housings, but using anything smaller than a .82 is stupid. YOUR PRICE: $1679.99 Thanks for looking!
Blouch TD06H-20G Turbocharger Application: Subaru WRX / STi Horsepower: 440 HP Bolt On: Yes The WRX/STi TD06H-20G enhances high boost pressure performance by substituting the larger TD06H high flow turbine for the TD05H turbine to reduce exhaust manifold/turbine housing backpressure while maintaining good throttle response. The 44 lb/min Mitsubishi 20G compressor wheel is installed in a true TD06 compressor housing and is paired with a 7 cm2 nozzle area turbine housing. Standard wastegate actuator is calibrated at 9 PSI and optional upgrade actuators are available in incremental pressures from 10 PSI to 19 PSI. The WRX/STi TD06H-20G custom performance turbocharger is a direct bolt on upgrade shipped complete with coolant pipes and turbo oil drain tube installed and requires no modification to intake, exhaust, oil and coolant connections for installation. *** This package includes braided stainless steel lines and the UPGRADED 8 cm2 turbine housing YOUR PRICE: $1359.99
