Hey everyone! TougeFest is approaching fast, and it's time to start getting our groups together to roll up there! Myself, Kevin, and some others are planning on meeting at the Chevron at the end of 400. Plans are tentatively: -Meet up at 10am -Run the Loop -Take 129 up to Fontana -Check in -Skyway Drive -First Dragon Run
yea me too, i still haven't washed the grime off my car from the last autox, i still have my numbers ghosted on the doors
Just friendly safety reminder... Check your brake fluid Bleed your brakes if you haven't done so in a while Change your oil Check to make sure you have enough brake pad Check Tire pressures and tread depth Check the torque on your lugs Check the torque on newly installed parts. I do this whole check list EVERYTIME before I go to the mountain or autox. Its a very good habit. Its most likely going to be colder up there than it is here, your tire pressures WILL drop with the change in temp. Bring tools... Hands tools, socket set, a hammer, pry bar, screw drivers, flash light, and zip ties. I keep this stuff in a tool bag in my car at all times, I've never had to use this stuff on my own car. However lots of people have been very thankful I had it. Over prepared is better than stuck because you don't have a 14mm with a 6 inch extension to tighten something that fell off or had shaken lose. Most of bring a clear mind... Its gonna damp and chilly up there. I look forward to meeting those you I haven't meet yet.
Thanks for the reminders!!!! Looking forward to meeting new folks and seeing everyone. Forester isn't exactly in any shape to be going on a major run but definitely looking forward to hanging out!
