saw one of these badboys today on the road...i just thuoght it was a concept but aparently not. Its pretty well prices staring at 21kmsrp. I personally like them.
I saw one on Friday and me and the fiance are going to test drive one tommrow, we are probally going to get rid of her civic. I think they look awesome in blue. Matt
Engine 4.0-liter DOHC 24-valve SFI VVT-i V6 239 hp @ 5200 rpm; 278 lb.-ft. @ 3700 rpm Ignition Electronic, with Toyota Direct Ignition System(TDIS) Transmission 5-speed electronically controlled automatic overdrive (ECT); 6-speed manual (full-time 4WD model) Drivetrain Rear-wheel 2WD or part-time 4WD for automatic transmission models; full-time 4WD for manual transmission models; automatic limited-slip differential (2WD model) Suspension High-mounted, double-wishbone front suspension and stabilizer bar; 4-link rear suspension with lateral rod with coil springs and stabilizer bar Steering Power-assisted variable-gear rack-and-pinion Turning circle diameter -- curb to curb (ft.) 41.8 Brakes Power-assisted 4-piston front/2-piston rear ventilated disc brakes with Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist [1] Vehicle Stability Control (VSC) [2] Standard Traction Control Standard Active Traction Control Available (4WD model) i still like the old ones better wanna talk about a car that holds its value
but currently there is an additional $4000-5000 "adjusted market price" on top of the msrp. i looked at the one on 78 also.
yeah i saw two of them back to back on Peachtree Ind.....they look like aggressive little Tonka trucks.....definitely gets your attention....
