Trans fluid change
Discussion in 'Modifications & DIY how-to' started by ddwyer50, Oct 22, 2006.
  1. ddwyer50
    ddwyer50 Member
    I really want to change my trans fluid. Is there a howto? I know its probably not *that* hard, just drain and refill, but where can I get the cocktail? Anyone have any pics or a howto on this?
    Thanks,
    Dennis
  2. crashtke
    There is a single plug on the tranny, not too hard to find, but if I remember ight it has a hex or star head socket that you need or something like that...anyway, take that plug out, let it drain over night then add your new fluid. I think it is under 4 quarts total...basicaly add 3.4, drive car, check, add a little tiny bit, check, drive car, repeat. As for where to get the cocktail, ya gonna have to look around for that...not sure you can get it all in one place most of the time.
  3. calmnothing
    I dont think you can find the cocktail anywhere at one place. You're probably gonna have to order the Castrol Hypoy-C from Midway Auto Supply. The Redline stuff from redline. And you can find syncromesh in most auto stores.
  4. 1ll-WRX
    I found the cocktail stuff at Mustangs Unlimited
