Trans fluid ?
Discussion in 'Introduce Yourself' started by cguzz, Sep 23, 2006.
  1. cguzz
    cguzz Member
    I'm getting close to 60k miles and I want to change my trans fluid and rear diff. I've got a 5mt in my WRX wagon. No problems with the tranny, I think it might even be better than some since I really don't have any sycro issues. I can dowshift to 1st even rolling a 10mph or better.
    Anyhow I'm still an after EM short of stage II with a gutted up and catless TBE.
    What tranny and rr diff. fluids do you guys reccomend?
    Thanks
  2. Weapon
    If you have not had any problems so far I would continue using Subaru fluids. Just dont use synthetic on the tranny! Synthetic in the diff is ok though.
  3. goixiz
    goixiz Active Member
    im using amsoil rear diff
    and still not decided for front /tranny yet - i have 4 qts of 75w-90 Valvoline and 1 qt of Pennzoil Syncromesh. I was planning to mix the both 3 qts of valv and remain syncromesh. I have in a clear glasscontainer a mix and have yet to check if the fluids blend
  4. cguzz
    cguzz Member
    Not sure I even have Subaru fluids. I bought the car w/40k.
  5. Weapon
    I recently swapped mine because I was having grinding issues from 3-4 and 4-5.
    The mix I tried was
    1 qt of valvoline 80w-90
    1 qt of GM syncromesh
    1 3/4 qt Castrol Hypoy C 80w-90
    I have had great results. No grinding what so ever. Heck I even try to make it grind and it wont! :sx:
  6. goixiz
    kris
    why valvoline and castrol mix ? any special reason ?
  7. cguzz
    cguzz Member
    Wow, maybe it's not my sloppy shifting. I do sometime miss the 2nd to 3rd shift when I'm pushing it real hard:eek: Is there a fluid that'll prevent my botched shifts:naughty: That grind really hurts, just when I notice I haven't missed it in a long time it happens again:wtc:
