turbo heatshield bracket
Discussion in 'Modifications & DIY how-to' started by blindfold, Nov 12, 2006.
  1. blindfold
    blindfold Active Member
    Hello everyone,
    I found a turbo heatshield bracket off a 02 wrx, does anyone know if this bracket will fit on a 04 STi VF39's 5 bolt downpipe pattern. Thank you.
  2. crashtke
    I think all the dp have the same pattern right? I mean a DP from a wrx will work on an Sti right? Don't take my word as gospel, but I think it should fit. Call one of the Subaru dealerships and ask if the part number from the WRX and STI heatshield bracket is different. If it is, then it might not fit.
  3. miloman
    the heat shield needs to be cut to fit with an aftermarket DP
  4. blindfold
    only looking for the heat shield bracket, I will most likley get a cusco or cobb shield but in order to do that I will need a bracket for the shield to be secured onto.
    Thank you crash for the advice.
  5. miloman
    i don't know how i missed that in your post... i think this weekend has left me brain dead
  6. jonnyboy0150
    jonnyboy0150 Member
    I believe all DP's are the same as far as WRX/STi is concerned. (99% positive)
  7. blindfold
    thank you guys for the input, really appreciate it.
