Hey guys I am getting a loud swooshing sound from the engine bay when the turbo engages. It's almost like a vacuum sound. My 2012 wrx is completely stock. I have an appointment set up with Subaru of Columbus but my concern is making that hour drive down there. Any clue what that might be ?
Check the coupling from intercooler to TB. I've seen them pop off quite often and the sound is close to what you're describing.
The last time I stopped by there the Subaru dealership was gone. That was about 3 weeks ago Sent from my iPhone using Tapatalk
122 Industrial Blvd McDonough, GA 30253 770-957-2497 http://www.subaruofmcdonough.com/index.htm They moved to McDonough
I called them also they said they are going out of business would not work on anything under warranty.
They can't do any work because all the mechs quit and the owner didn't want to spend the money to remodel
Matt you were correct, it was the coupler from the inter-cooler to the throttle-body. At the angel I could see it, all looked fine. When the mechanic at the dealership showed it to me it was f*(% up. And thank you Brian for suggesting an aftermarket coupler I am ordering it today. You guys are awesome thanks again.
