Turbo noise.
Discussion in 'Modifications & DIY how-to' started by FrankenSTI, Apr 13, 2006.
  1. FrankenSTI
    FrankenSTI Member
    My stock wrx turbo was making a hideous noise at 5000 rpms and above so i went ahead and changed it to an sti turbo, now it seems that the sti turbo is faintly making the same noise , it sounds like a a grinding and squealing noise combined. Seems like it isnt getting any oil to the turbo.
    This all started after I put on my up pipe, any suggestions.
    I have never heard of this problem before.
  2. Brian
    Brian Active Member
    Since the old turbo had the same problem, have you verified oil is flowing to the turbo? And that it's really the turbo, not an engine bearing?
  3. FrankenSTI
    FrankenSTI Member
    No I havent checked the oil line really we got done late last night but I will definetly check it after work. I hope its not an engine bearing, the block and everything are pretty much brand new. the noise does sound like the turbo might be dry spinning.
  4. bluetwo
    bluetwo Active Member
    I'd have it checked out by a technician as soon as possible. It could be even more serious than that.
  5. Brian
    Brian Active Member
    I'm assuming you primed the oil lines before starting the car too.
  6. FrankenSTI
    FrankenSTI Member
    Yes i did
  7. Alex
    Take the car back to TS and have them look at it.
  8. wrxbacano
    wrxbacano Member
    Did it feel any different with the STI turbo??
  9. FrankenSTI
    FrankenSTI Member
    Havent drove it yet with the sti on . I dont have the money to take it to topspeed right now if i did it would be there.
    This all started when I replaced my stock up pipe with a HKS up pipe, it is a solid pipe not a flex pipe. cold this have any thing to do with it?
  10. Brian
    Brian Active Member
    Only if your oil line got crimped or pinched when installing the UP. Or there was debris dropped into the pipes.
